0015030 | ParaView | (No Category) | public | 2014-10-06 04:16 | 2016-08-12 09:59 | ||||
Reporter | Joachim Pouderoux | ||||||||
Product Version | 4.2 | ||||||||
Summary | 0015030: Find Data fails to select a cell or a point from an ID | ||||||||
Description | Tested on official release of ParaView 4.2@Win64 (on a french PC). Start ParaView. Create a Sphere source. Open the Find Data panel ('V'). Find "Cell(s) from Sphere1. ID is " type 1 as cell ID to select. Press Run Selection Query. Nothing is selected and the following message appears in the Output Messages window: Traceback (most recent call last): File "<string>", line 8, in <module> File "<string>", line 5, in vtkPythonExtractSelection_RequestData File "C:\Program Files (x86)\ParaView 4.2.0\lib\paraview-4.2\site-packages\paraview\extract_selection.py", line 111, in execute output.FieldData.append(nonzero_indices, "vtkSelectedIds"); File "C:\Program Files (x86)\ParaView 4.2.0\lib\paraview-4.2\site-packages\paraview\vtk\numpy_interface\dataset_adapter.py", line 535, in append arr = numpyTovtkDataArray(copy, name) File "C:\Program Files (x86)\ParaView 4.2.0\lib\paraview-4.2\site-packages\paraview\vtk\numpy_interface\dataset_adapter.py", line 119, in numpyTovtkDataArray vtkarray = numpy_support.numpy_to_vtk(array) File "C:\Program Files (x86)\ParaView 4.2.0\lib\paraview-4.2\site-packages\vtk\util\numpy_support.py", line 141, in numpy_to_vtk result_array = create_vtk_array(vtk_typecode) File "C:\Program Files (x86)\ParaView 4.2.0\lib\paraview-4.2\site-packages\vtk\util\numpy_support.py", line 97, in create_vtk_array return vtk.vtkDataArray.CreateDataArray(vtk_arr_type) TypeError: CreateDataArray argument 1: an integer is required | ||||||||
Project | TBD | ||||||||
(0038672) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-10-06 04:16 | Joachim Pouderoux | New Issue | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038672 | |
