0015033 | ParaView | (No Category) | public | 2014-10-06 05:07 | 2016-08-12 09:59 | ||||
Reporter | Joachim Pouderoux | ||||||||
Priority | low | Severity | minor | Reproducibility | have not tried | ||||
Summary | 0015033: Adding a "Duplicate" functionality to Source to allow multiple representations in a same view | ||||||||
Description | So far if you want to visualize a source with 2 different representations (eg. Surface AND Points), you have to create it a second time which means duplicate the memory needs, or pass it to a "dummy filter" (eg. through a Pass Array filter). It would be great to add a "Duplicate" menu entry in the Source right-click entry that would perform some kind of shallowcopy of the source. | ||||||||
Project | TBD | ||||||||
Type | feature | ||||||||
(0038673) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-10-06 05:07 | Joachim Pouderoux | New Issue | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038673 | |
