0015058 | ParaView | (No Category) | public | 2014-10-21 21:41 | 2015-01-09 13:33 | ||||
Product Version | 4.2 | ||||||||
Target Version | 4.3 | Fixed in Version | 4.3 | ||||||
Summary | 0015058: (Venus) Log 2d plots go too high | ||||||||
Description | PV 4.2.0, Linux, local server. I bet that this can be replicated easier than this, but this is what I have. Also, the effect is worse as you stretch ParaView wider in the horizontal direction, while leaving it fairly short in the vertical direction. Furthermore, if you make the lower 2d window smaller vertically, the effect gets even more pronounced. * Open can.exo. Al vars on. Apply. * Go to the last time step. * Plot over line. Apply. * Split the 2d viewport vertically, and turn on visibility for the Plot Over Line. * Left Axis Range - check Left Axis Use Custom Range. Use [1, 4000000] (one to four million). Check Left Axis Log Scale. <<bug>> Notice that the horizontal lines from the left axis grid go off the top of the plot. This needs to be fixed. Attaching a screenshot. | ||||||||
Project | Sandia | ||||||||
Topic Name | vtk_master_20141105 | ||||||||
Attached Files | log-plot-bug-screenshot.png [^] (194,306 bytes) 2014-10-21 21:45
(0033717) Utkarsh Ayachit (administrator) 2014-11-04 15:47 |
A VTK fix is awaiting review: http://review.source.kitware.com/#/t/4938 [^] |
(0033727) Utkarsh Ayachit (administrator) 2014-11-05 10:15 |
This is a VTK Commit: commit 25e393890bd8dac1ebae19d522203e30546fa9dc Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Tue Nov 4 15:44:22 2014 -0500 BUG 0015058: Fixes unclipped grid. vtkChartXY wouldn't clip the grid. There doesn't seem to be a good reason for that. We should clip the grid to match clipping/transformation used by the axes and other plots. This avoid visualization where the grid extends beyond the axes/plots. Change-Id: I5bd43f65f27f437832bf33ef6230084de7988367 |
(0033743) Utkarsh Ayachit (administrator) 2014-11-06 08:44 |
Topics merged into master: 14845_reset_color_map 15053_fix_coloring_with_missing_arrays 15085_fix_install_rules_for_catalyst 15107_catalyst_rendering_edition opengl2-backend (VTK) vtk_master_20141105 |
(0033753) Alan Scott (manager) 2014-11-06 16:08 |
Tested Master, Linux, local server. |
2014-10-21 21:41 | Alan Scott | New Issue | |
2014-10-21 21:45 | Alan Scott | File Added: log-plot-bug-screenshot.png | |
2014-10-21 21:46 | Alan Scott | Target Version | => 4.3 |
2014-11-04 09:53 | Utkarsh Ayachit | Target Version | 4.3 => bug_fix |
2014-11-04 15:47 | Utkarsh Ayachit | Note Added: 0033717 | |
2014-11-04 15:47 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2014-11-05 10:15 | Utkarsh Ayachit | Topic Name | => vtk_master_20141105 |
2014-11-05 10:15 | Utkarsh Ayachit | Note Added: 0033727 | |
2014-11-05 10:15 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2014-11-05 10:15 | Utkarsh Ayachit | Fixed in Version | => git-next |
2014-11-05 10:15 | Utkarsh Ayachit | Resolution | open => fixed |
2014-11-06 08:44 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2014-11-06 08:44 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-11-06 08:44 | Utkarsh Ayachit | Note Added: 0033743 | |
2014-11-06 16:08 | Alan Scott | Note Added: 0033753 | |
2014-11-06 16:08 | Alan Scott | Status | customer review => closed |
2014-11-14 22:56 | Utkarsh Ayachit | Target Version | bug_fix => 4.3 |
2015-01-02 10:45 | Utkarsh Ayachit | Fixed in Version | git-master => 4.3 |
2015-01-09 13:33 | Utkarsh Ayachit | Source_changeset_attached | => VTK master 2bc4c6cc |
2015-01-09 13:33 | Utkarsh Ayachit | Source_changeset_attached | => VTK master e18424bc |
2015-01-09 13:33 | Utkarsh Ayachit | Source_changeset_attached | => VTK master 25e39389 |
