0015060 | ParaView | (No Category) | public | 2014-10-21 22:11 | 2015-01-11 08:15 | ||||
Product Version | 4.2 | ||||||||
Target Version | 4.3 | Fixed in Version | 4.3 | ||||||
Summary | 0015060: (Venus) TemporalShiftScale doesn't update 2d correctly | ||||||||
Description | Not sure where the fault is here, I can only give you the end bug. * Linux, 4.2.0, local server. The goal here is to be able to change time units in a 2d plot to something reasonable. User has time that is in 1e-13 seconds, wants to change to 1e-4 nanoseconds. * Open can.exo. All variables on. Apply. * Last time step. * Temporal Shift Scale filter. Apply. * Plot over line filter. Change Chart Title to "Time = ${TIME} Milliseconds" * Now, click on Temporal Shift Scale filter. Change scale to 1000. Apply. <<Bug>> - the time in the title of the 2d plot didn't change! You can make it change by moving forward/ back in time. | ||||||||
Project | Sandia | ||||||||
Topic Name | 0015060_fix_temporalshift_issue | ||||||||
(0033710) Utkarsh Ayachit (administrator) 2014-11-04 13:43 |
commit 4a3f368706874d3efc25c7188e4c8543c58c6345 Author: Utkarsh Ayachit <utkarsh.ayachit@kitware.com> Date: Tue Nov 4 13:40:58 2014 -0500 BUG 0015060. Fixed issue when using TemporalShiftScale. The problem was that when the current timesteps changed, we didn't snap the current time to the new timesteps. That meant that we continued to show the same old timestep even though the pipeline timesteps changed. We fix this behavior by ensuring that we snap to a valid timestep when the timesteps change and the animation is in "snap to timesteps" mode. Change-Id: Ib6d1c1ca22eedf84cc8e9aa36592ad403d10a172 |
(0033720) Utkarsh Ayachit (administrator) 2014-11-05 08:11 |
SUMMARY --------------------------------------------- Topics merged into master: 0015060_fix_temporalshift_issue 15059_fix_time_comments 15100_fix_color_map_editor_size python_syntax_highlighting_bugs test_max (VTK) vtk_master_20141104 |
(0033761) Alan Scott (manager) 2014-11-06 17:34 |
Not sure if I like this solution, but I can't think of a better one. It also fixes this specific bug. I will write up another if my customer doesn't like this. Tested Linux, master, local server. |
2014-10-21 22:11 | Alan Scott | New Issue | |
2014-10-21 22:11 | Alan Scott | Target Version | => 4.3 |
2014-11-04 09:52 | Utkarsh Ayachit | Target Version | 4.3 => bug_fix |
2014-11-04 13:43 | Utkarsh Ayachit | Topic Name | => 0015060_fix_temporalshift_issue |
2014-11-04 13:43 | Utkarsh Ayachit | Note Added: 0033710 | |
2014-11-04 13:43 | Utkarsh Ayachit | Status | backlog => gatekeeper review |
2014-11-04 13:43 | Utkarsh Ayachit | Fixed in Version | => git-next |
2014-11-04 13:43 | Utkarsh Ayachit | Resolution | open => fixed |
2014-11-04 13:43 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2014-11-05 08:10 | Utkarsh Ayachit | Fixed in Version | git-next => git-master |
2014-11-05 08:11 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2014-11-05 08:11 | Utkarsh Ayachit | Note Added: 0033720 | |
2014-11-06 17:34 | Alan Scott | Note Added: 0033761 | |
2014-11-06 17:34 | Alan Scott | Status | customer review => closed |
2014-11-14 22:56 | Utkarsh Ayachit | Target Version | bug_fix => 4.3 |
2015-01-02 10:45 | Utkarsh Ayachit | Fixed in Version | git-master => 4.3 |
2015-01-11 08:15 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master a4fb3298 |
2015-01-11 08:15 | Utkarsh Ayachit | Source_changeset_attached | => ParaView master 4a3f3687 |
