0015083 | ParaView | (No Category) | public | 2014-10-29 09:33 | 2016-08-12 09:59 | ||||
Reporter | Thomas Briffard | ||||||||
Product Version | 4.2 | ||||||||
Summary | 0015083: Wrong point labels (ID) with paraview 4.2 | ||||||||
Description | I have wrong point labels (ID) with Paraview 4.2. Linux (Fedora 19), Paraview 4.2, what I'm doing : * open exempleID.vtu * go to View->SelectionDisplayInspector * Point Labels * activate ID ID displayed are (6.91e-310,6.91e-310,6.91e-310,6.95e-310), they should be (0,1,2,3). Everything works fine using Paraview 4.1. | ||||||||
Project | TBD | ||||||||
Attached Files | exempleID.vtu [^] (1,688 bytes) 2014-10-29 09:33 | ||||||||
(0033682) Utkarsh Ayachit (administrator) 2014-10-31 16:04 |
Click on the "gear" to popup the "Advanced Selection Display Properties" dialog. There, enter %d for the "Point Label Format" instead of the default %-#6.3g. That should address the problem. |
(0033686) Thomas Briffard (reporter) 2014-11-03 08:22 |
Indeed, this manipulation fix the problem, thanks. |
(0038696) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-10-29 09:33 | Thomas Briffard | New Issue | |
2014-10-29 09:33 | Thomas Briffard | File Added: exempleID.vtu | |
2014-10-31 16:04 | Utkarsh Ayachit | Note Added: 0033682 | |
2014-11-03 08:22 | Thomas Briffard | Note Added: 0033686 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038696 | |
