0001509 | ParaView | (No Category) | public | 2005-01-21 11:55 | 2009-12-09 14:50 | ||||
Reporter | Lee Ankeny | ||||||||
Assigned To | Amy Squillacote | ||||||||
Summary | 0001509: LA: pvbatch can't write data | ||||||||
Description | PV's 'save batch script' doesn't write out commands to save data to files. And apparently pvbatch is incapable of doing so anyway. | ||||||||
Attached Files | testBatch.pvb [^] (4,385 bytes) 1969-12-31 19:00 | ||||||||
(0002000) Amy Squillacote (reporter) 2005-01-28 13:44 |
In the CVS version of ParaView, it is now possible to hand-modify a batch script to write out data files. I am now working on having ParaView write out the appropriate commands when a batch script is saved. |
(0002182) Amy Squillacote (reporter) 2005-03-15 11:14 |
Berk has been working on this. If you manually change the batch script, you can write out data files from it. However, it is not currently possible for this information to be stored when you save a batch script from ParaView because there is no vtkPVSource for writers. |
2009-12-09 14:50 | Berk Geveci | Project | @3@ => ParaView |
