0015096 | ParaView | (No Category) | public | 2014-10-30 21:14 | 2016-08-12 09:59 | ||||
Product Version | 4.2 | ||||||||
Summary | 0015096: Optionally automatically link the color transfer function and the opacity transfer function | ||||||||
Description | We need the ability to automatically create color transfer function points whenever we create an opacity transfer function point. When volume rendering something like fire, you always want to have an opacity and color. So, when you click on the Opacity transfer function slanted line, creating a point, I expect to see a matching point appear on the Color transfer function. The quick version is: Wavelet, RTData, Volume render. Now open the Color Map Editor. Click on the sloped Mapping Data line. A matching color point should appear. This is currently done by hand, manually, getting it as good as possible, or double entering the data in the transfer function tables. Not good. | ||||||||
Project | Sandia | ||||||||
Type | feature | ||||||||
(0038699) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-10-30 21:14 | Alan Scott | New Issue | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038699 | |
