0015110 | ParaView | (No Category) | public | 2014-11-06 16:46 | 2016-08-12 09:59 | ||||
Reporter | Jan Brezina | ||||||||
Product Version | 4.2 | ||||||||
Summary | 0015110: chaotic edges in 'surface with edges' view | ||||||||
Description | The visibility of edges in the 'surface with edges' view is chaotic. Frontface edges seems to be randomly overlaped by surface polygons. Some backface edges are visible. Reproduce: 1) create a box source 2) rotate, edges switch visibility with rotation; some backface edges could be observed. Similar for sphere source (no wrong back face edges there) and cone source. First observed for a complex unstructured grids of hexahedra. I think this works fine with 3.98, but not sure. Adding some screens demonstrating the issue. | ||||||||
Project | TBD | ||||||||
Attached Files | box_wrong_backface.png [^] (5,394 bytes) 2014-11-06 16:46
(0038705) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-11-06 16:46 | Jan Brezina | New Issue | |
2014-11-06 16:46 | Jan Brezina | File Added: box_wrong_backface.png | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038705 | |
