0015120ParaView(No Category)public2014-11-12 01:422016-08-24 08:25
ReporterRouven Weiler
Assigned ToKitware Robot
StatusclosedResolutionmoved
PlatformOSOS Version
Product Version4.2
Summary0015120: Error When Using Point Sprite in Client-Server Mode
DescriptionWhen using the point-sprite plugin in client-server mode I get the following error when changing the view to point sprite:
ERROR: In /share/software/apps/Kitware.Inc/paraview/paraview.build-4.2.0/paraview/src/paraview/VTK/Common/ExecutionModel/vtkDemandDrivenPipeline.cxx, line 710
vtkCompositeDataPipeline (0x89b63a0): Input port 0 of algorithm vtkAppendPolyData(0x72c2ed0) has 0 connections but is not optional.
Paraview then freezes immediately on the client.
The server is used with software rendering while the client uses hardware rendering.
TagsNo tags attached.
ProjectTBD
Topic Name
Typecrash
 Relationships
  Notes
(0038711)
Kitware Robot (administrator)
2016-08-12 09:59
Resolving issue as `moved`.
 Issue History
2014-11-12 01:42 Rouven Weiler New Issue
2016-08-12 09:59 Kitware Robot Note Added: 0038711
2016-08-12 09:59 Kitware Robot Status backlog => closed
2016-08-12 09:59 Kitware Robot Resolution open => moved
2016-08-12 09:59 Kitware Robot Assigned To => Kitware Robot
2016-08-24 08:25 Kitware Robot View Status private => public
