0015136 | ParaView | (No Category) | public | 2014-11-18 18:48 | 2016-08-12 09:59 | ||||
Product Version | 4.2 | ||||||||
Summary | 0015136: Can't select cells correctly in vtu file | ||||||||
Description | I can't seem to select cells properly with the attached trivial .vtu file. This is a bug. * Window, local server, 4.2.0 * This dataset looks like a pyramid. Click -Z. * Select cells on. Try to select a face. You can't do it. Note that I am remote desktop'd into my work computer - I wonder if that is an issue.. | ||||||||
Project | Sandia | ||||||||
Attached Files | sampleUnstructuredQuads3d.vtu [^] (1,303 bytes) 2014-11-18 18:55 | ||||||||
(0038716) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-11-18 18:48 | Alan Scott | New Issue | |
2014-11-18 18:55 | Alan Scott | Summary | Can't select cells correctly in vtk file => Can't select cells correctly in vtu file |
2014-11-18 18:55 | Alan Scott | Description Updated | |
2014-11-18 18:55 | Alan Scott | File Added: sampleUnstructuredQuads3d.vtu | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038716 | |
