0015141ParaView(No Category)public2014-11-20 03:562015-01-02 10:43
ReporterJoachim Pouderoux
Assigned ToJoachim Pouderoux
StatusclosedResolutionfixed
PlatformOSOS Version
Product Versiongit-master
Target VersionFixed in Version4.3
Summary0015141: Imp: Improve the 3D view manipulation for long objects
DescriptionFor objects which have a dimension much bigger than the others, the view manipulation is not easy, because the rotation is too fast.
As an example, create a cylinder source with the properties:
 - Resolution: 36
 - Height: 200
 - Radius: 0.5
and make several zooms and rotations to see the problems.
TagsNo tags attached.
ProjectParaViS
Topic Name0015141_add_rotation_factor
Typefeature
 Relationships
  Notes
(0033824)
Joachim Pouderoux (developer)
2014-11-20 10:43
http://review.source.kitware.com/18078 [^]
Change If3558c89: Add a rotation factor to improve 3D manipulation of long objects
A "RotationFactor" property is added to the interactor style and the
Adjust Camera dialog box in the UI.
Change-Id: If3558c89693687459619f94a9976e8aaa498706b
(0033854)
2014-11-27 11:39
Topics merged into master (v4.2.0-153-g044be9b)
        0015144_subticks_marks_deactivation
        0015146_add_SelectPoints_function_in_pvsimple
        15137_fix_label_format
        15148_ADIOS_require_MPI
(VTK) kdtree-repr
        qtEvent_player_fix
(VTK) update-hdf5
(VTK) vtk_20141122
(0033873)
Alan Scott (manager)
2014-12-02 15:53
Nice.
Tested remote server, Linux, master.
 Issue History
2014-11-20 03:56 Joachim Pouderoux New Issue
2014-11-20 03:56 Joachim Pouderoux Assigned To => Joachim Pouderoux
2014-11-20 10:43 Joachim Pouderoux Topic Name => 0015141_add_rotation_factor
2014-11-20 10:43 Joachim Pouderoux Status backlog => active development
2014-11-20 10:43 Joachim Pouderoux Note Added: 0033824
2014-11-22 06:59 Joachim Pouderoux Status active development => gatekeeper review
2014-11-22 06:59 Joachim Pouderoux Resolution open => fixed
2014-11-27 11:38 Utkarsh Ayachit Fixed in Version => git-master
2014-11-27 11:39 Utkarsh Ayachit Status gatekeeper review => customer review
2014-11-27 11:39 Utkarsh Ayachit Note Added: 0033854
2014-12-02 15:53 Alan Scott Note Added: 0033873
2014-12-02 15:53 Alan Scott Status customer review => closed
2015-01-02 10:43 Utkarsh Ayachit Fixed in Version git-master => 4.3
