0015147 | ParaView | (No Category) | public | 2014-11-22 07:58 | 2016-08-12 09:59 | ||||
Reporter | Joachim Pouderoux | ||||||||
Assigned To | Joachim Pouderoux | ||||||||
Product Version | git-next | ||||||||
Summary | 0015147: Imp: In the bar chart, display the ticks limiting each bar by default | ||||||||
Description | When calling the filter histogram, a bar chart view is created with rounded values in the X-axis. In order to know a bar correspond to which interval, the X-axis must have values corresponding to the interval of computation of each bar. This can be obtained via: - View properties - Bottom axis layout - Specify axis labels explicitly - Generate: - From: min value of the field - To: max value of the field - Steps: number of bars + 1 This should be the default behaviour so as to understand what each bar means. | ||||||||
Project | ParaViS | ||||||||
Type | feature | ||||||||
(0038719) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-11-22 07:58 | Joachim Pouderoux | New Issue | |
2014-11-22 07:58 | Joachim Pouderoux | Assigned To | => Joachim Pouderoux |
2014-11-22 07:58 | Joachim Pouderoux | Status | backlog => active development |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038719 | |
2016-08-12 09:59 | Kitware Robot | Status | active development => closed |
