0015151 | ParaView | (No Category) | public | 2014-11-25 11:13 | 2016-08-12 09:59 | ||||
Reporter | Llion Evans | ||||||||
Product Version | 4.2 | ||||||||
Summary | 0015151: EnSight Gold Material Files Format cannot be read by vtkEnSightReader.cxx | ||||||||
Description | It seems as though there is currently a bug in vtkEnSightReader.cxx which does not allow Material IDs to be read using the EnSight Gold format. According to the EnSight user manual (Page 713, http://www3.ensight.com/EnSight10_Docs/UserManual.pdf [^]); "The material id file follows the same syntax as the per_element variable files, except that its values are integers for each element of designated types of designated parts..." The error reported by ParaView is; ERROR: In C:\DBD\pvs-x64\paraview\src\paraview\VTK\IO\EnSight\vtkEnSightReader.cxx, line 967 vtkEnSightGoldBinaryReader (000000000CE56060): invalid VARIABLE line: MATERIAL | ||||||||
Project | TBD | ||||||||
(0038720) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-11-25 11:13 | Llion Evans | New Issue | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038720 | |
