0015162 | ParaView | (No Category) | public | 2014-11-30 21:40 | 2016-08-12 09:59 | ||||
Reporter | Ken Sheldon | ||||||||
Product Version | 4.2 | ||||||||
Summary | 0015162: XDMF Bug (Hard-coded drive letter C:) | ||||||||
Description | It appears ParaView uses the wrong drive letter when writing or reading HDF5 files via XDMF. Steps to reproduce: Start ParaView (I am using Version 4.2.0 64 Bit for Windows 7 64-bit) From the menu, select Sources --> Plane Set X Resolution 10 Set Y Resolution 10 Apply File --> Save Data File format Xdmf data file File name D:\SAMPLE.XMF Open the XMF file in a text editor. Bug 1: The file refers to D:/SAMPLE.h5 . However, there is no such file. The HDF5 file is C:\SAMPLE.H5. Bug 2: Reset the ParaView session and open the file D:\SAMPLE.XMF. Apply. The data loads properly, although the XMF file refers to D:/SAMPLE.h5, which does not exist. Bug 2.1: Reset the ParaView session. Move the file SAMPLE.H5 to D:\ (The directory referenced in D:\SAMPLE.XMF) In Paraview, select File --> Open SAMPLE.XMF. Apply. The program displays the Output Messages window with the following error message: ERROR: In C:\DBD\pvs-x64\paraview\src\paraview\VTK\IO\Xdmf2\vtkXdmfReader.cxx, line 409 vtkXdmfReader (000000000EA5E7E0): Failed to read data. ERROR: In C:\DBD\pvs-x64\paraview\src\paraview\VTK\Common\ExecutionModel\vtkExecutive.cxx, line 783 vtkPVCompositeDataPipeline (000000000DBCCA70): Algorithm vtkFileSeriesReader(000000000DBCC5C0) returned failure for request: vtkInformation (000000000C4FE530) Debug: Off Modified Time: 673302 Reference Count: 1 Registered Events: (none) Request: REQUEST_DATA ALGORITHM_AFTER_FORWARD: 1 FORWARD_DIRECTION: 0 FROM_OUTPUT_PORT: 0 | ||||||||
Tags | XDMF | ||||||||
Project | TBD | ||||||||
(0038725) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-11-30 21:40 | Ken Sheldon | New Issue | |
2014-12-01 11:36 | Ken Sheldon | Tag Attached: XDMF | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038725 | |
