0015169 | ParaView | (No Category) | public | 2014-12-02 19:44 | 2016-08-12 09:59 | ||||
Reporter | Erwin | ||||||||
Product Version | 4.2 | ||||||||
Summary | 0015169: volume rendering error on local Windows 7 x64, AMD Radeon 5450/6350, OpenGL 4.4 | ||||||||
Description | Using both ParaView 4.2 and 4.2.0-97-g33e1c33 64-bit I encounter a volume rendering error when walking through Exercise 2.14 of the tutorial book ParaviewTutorial42: open disk_out_ref.ex2 select all variables apply Coloring -> Temp Representation -> Volume ERROR: In C:\DBD\pvs-x64\paraview\src\paraview\VTK\Rendering\VolumeOpenGL\vtkOpenGLProjectedTetrahedraMapper.cxx, line 188 vtkOpenGLProjectedTetrahedraMapper (000000001581A8E0): The required extensions are not supported. This problem occurs on a local server. Additional details: OpenGL 6.14.10.13084 (According to AMD Catalyst Control Center) OpenGL 4.4 (According to OpenGL Extensions Viewer) | ||||||||
Project | TBD | ||||||||
(0033878) David C. Lonie (developer) 2014-12-03 07:59 |
Unassigning myself, as I'm working on different projects these days. |
(0034014) jzhou (reporter) 2014-12-29 03:41 edited on: 2014-12-29 03:41 |
Hi David, here is my find for this issue: issue 1: vtk disable AMD hw rendering in vtkOpenGLProjectedTetrahedraMapper::IsSupported(vtkRenderWindow *rwin) { ... // exclude ATI Radeon HD, except on Apple, because there seems to // be a bug in ATI's legacy fixed function texturing support in recent // drivers. The Radeon HD cards are identified here by the OpenGL version // because the renderer string is inconsistent across platforms. // win7 RHD5800, win7 RHD6750M, Linux RHD7870 all exhibit the bug. bool driverSupport #if defined(__APPLE__) = true; #else = !(extensions->DriverIsATI() && (extensions->GetDriverGLVersionMajor() >= 3)) || extensions->GetIgnoreDriverBugs("ATI texturing bug"); #endif return texSupport && driverSupport; } issue 2: the mentioned texturing bug in issue 1 is: void vtkOpenGLProjectedTetrahedraMapper::Render(vtkRenderer *renderer, vtkVolume *volume) { … glTexImage2D(GL_TEXTURE_2D, 0, GL_INTENSITY, TEXRES, TEXRES, 1, GL_RED, GL_FLOAT, texture); … } the 6th parameter 'border’ of glTexImage2D must be 0 according to opengl spec. But it is set 1 in vtkOpenGLProjectedTetrahedraMapper::Render now. I think after resolving these issues, volume rendering will work on AMD card. |
(0038728) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-12-02 19:44 | Erwin | New Issue | |
2014-12-02 19:44 | Erwin | Assigned To | => David C. Lonie |
2014-12-03 07:58 | David C. Lonie | Assigned To | David C. Lonie => |
2014-12-03 07:59 | David C. Lonie | Note Added: 0033878 | |
2014-12-29 03:41 | jzhou | Note Added: 0034014 | |
2014-12-29 03:41 | jzhou | Note Edited: 0034014 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038728 | |
