0015173 | ParaView | (No Category) | public | 2014-12-03 11:47 | 2015-12-11 14:54 | ||||
Reporter | Joachim Pouderoux | ||||||||
Assigned To | Joachim Pouderoux | ||||||||
Status | closed | Resolution | suspended | ||||||
Summary | 0015173: Imp: Add UI control to activate/deactivate 3D stereo and to select the stereo mode | ||||||||
Description | Currently, 3D view can be changed to stereo mode only at ParaView start-up with the following options: --stereo:--stereo-type=SplitViewportHorizontal or by some python code: GetRenderView().StereoRender=1 GetRenderView().StereoType="SplitViewportHorizontal" To be more user friendly, we need an icon in the top of 3D views to be able to activate/deactivate 3D stereo and to select which stereo mode to use in a drop-down list. | ||||||||
Project | ParaViS | ||||||||
Topic Name | 0015173_stereo_toolbar | ||||||||
Type | feature | ||||||||
(0033895) Joachim Pouderoux (developer) 2014-12-04 09:14 |
http://review.source.kitware.com/#/c/18243/ [^] Change I261e1825: Add a new stereo toolbar to enable/configure stereo mode Add a new stereo toolbar to enable/configure stereo mode The toolbar expose a button that allows to enable/disable stereo and the attached menu let you choose which stereo mode you want to set to the active view. Change-Id: I261e1825ca483b21bcd0c79df8b77663067a7677 |
(0035065) Mathieu Westphal (developer) 2015-08-26 10:10 |
fixed by: https://gitlab.kitware.com/paraview/paraview/merge_requests/330 [^] |
(0035173) Mathieu Westphal (developer) 2015-09-04 05:32 |
patch v2 cannot be integrated, for it is not working in Client/Server mode: Failing test pvserver, 3 ranks, with remote render threshold set to 0. Check "Stereo Render", change Stereo Mode to "Red/Blue" -- so far so good. Split view and create another render view. Segfault. |
2014-12-03 11:47 | Joachim Pouderoux | New Issue | |
2014-12-03 11:47 | Joachim Pouderoux | Assigned To | => Joachim Pouderoux |
2014-12-03 11:49 | Joachim Pouderoux | Topic Name | => 0015173_stereo_ui_controls |
2014-12-03 13:08 | Joachim Pouderoux | Note Added: 0033893 | |
2014-12-03 13:08 | Joachim Pouderoux | Status | backlog => active development |
2014-12-04 09:14 | Joachim Pouderoux | Note Added: 0033895 | |
2014-12-04 09:15 | Joachim Pouderoux | Note Deleted: 0033893 | |
2014-12-04 09:15 | Joachim Pouderoux | Topic Name | 0015173_stereo_ui_controls => 0015173_stereo_toolbar |
2015-08-26 10:10 | Mathieu Westphal | Note Added: 0035065 | |
2015-08-26 10:10 | Mathieu Westphal | Status | active development => gatekeeper review |
2015-08-26 10:10 | Mathieu Westphal | Resolution | open => fixed |
2015-09-04 05:31 | Mathieu Westphal | Resolution | fixed => suspended |
2015-09-04 05:32 | Mathieu Westphal | Note Added: 0035173 | |
2015-12-11 14:54 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2015-12-11 14:54 | Utkarsh Ayachit | Status | customer review => closed |
