0015209 | ParaView | (No Category) | public | 2014-12-15 11:11 | 2016-08-12 09:59 | ||||
Reporter | Vadim SANDLER | ||||||||
Assigned To | Joachim Pouderoux | ||||||||
Priority | immediate | Severity | minor | Reproducibility | have not tried | ||||
Product Version | 4.2 | ||||||||
Summary | 0015209: Paraview crashes after closing X window when a model is rendered by the pvserver | ||||||||
Description | Tested on Linux platform: - launch a pvserver - launch paraview - connect paraview to the pvserver - Create a sphere (Theta Resolution=10000, Phi Resolution=1000) as a result size of the presentation is about 57MB (bigger then "Remote Render Threshold" = 20 by default; note that if the model is not big enough, you can apply the reflect filter to increase the size of the rendered model). => The model is displayed in the "Render View" as expected and in the OpenGL X window. If you close this X window, ParaView crashes with the error "vtkClientSocket (0x33c4f50): Socket error in call to send. Broken pipe". | ||||||||
Project | ParaViS | ||||||||
Type | crash | ||||||||
(0033965) Vadim SANDLER (reporter) 2014-12-15 11:15 |
Sorry for the misprint in the initial Description, resolutions of the sphere are the following: Theta Resolution = 10000; Phi Resolution = 10000. |
(0033966) Joachim Pouderoux (developer) 2014-12-15 11:35 edited on: 2014-12-15 11:36 |
Is this a bug? If you configure your client to do remote rendering, the server will do the rendering and sends the images back to the client so it can display it. The "X" window you see is the one created by the server (but in your case client & server are on the same computer). You are not supposed to close it, otherwise you kill the server and thus break the connection between the client and the server. |
(0038744) Kitware Robot (administrator) 2016-08-12 09:59 |
2014-12-15 11:11 | Vadim SANDLER | New Issue | |
2014-12-15 11:11 | Vadim SANDLER | Assigned To | => Tristan Coulange |
2014-12-15 11:15 | Vadim SANDLER | Note Added: 0033965 | |
2014-12-15 11:28 | Tristan Coulange | Assigned To | Tristan Coulange => Joachim Pouderoux |
2014-12-15 11:35 | Joachim Pouderoux | Note Added: 0033966 | |
2014-12-15 11:36 | Joachim Pouderoux | Note Edited: 0033966 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038744 | |
