0015262 | ParaView | (No Category) | public | 2015-01-13 20:52 | 2016-08-12 09:59 | ||||
Product Version | 4.4 | ||||||||
Summary | 0015262: Plot selection over time time marker broken | ||||||||
Description | The Plot Selection over Time - time marker is broken. This seems to occur in strange cases. I will present a good case below, followed by two bad cases. <<Good>> * Linux, 4.3.0, local server. * can.exo. All vars on. Apply. * Rotate the dataset with the mouse, so you can see the can. * Select Cells On the can (can, not plate). * Plot selection over time. * Next frame. Notice that the green vertical line appears. This is correct behavior. (If not, you messed up a step.) * Reset Session <<Bad>> * Linux, 4.3.0, local server. * can.exo. All vars on. Apply. * >>>> Do not move the can with your mouse. <<<< * Select Cells On the plate. Select the cell that is in the upper left corner of the plate. * Plot selection over time. * Next frame. Notice that the green vertical line DOES NOT appear. This is a bug. (If you see the green line, you messed up a step.) * Reset Session <<Bad>> * Linux, 4.3.0, local server. * can.exo. All vars on. Apply. * Surface with edges. * Move the can with the mouse so you can see the can. OK to zoom in with right mouse button if you want. * Select Points On the can. Rubber band select a point. * Plot selection over time. * Next frame. Notice that the green vertical line DOES NOT appear. This is a bug. (If you see the green line, you messed up a step.) | ||||||||
Project | Sandia | ||||||||
Relationships | ||||||
(0038759) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-01-13 20:52 | Alan Scott | New Issue | |
2016-06-14 16:18 | Alan Scott | Relationship added | related to 0016747 |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038759 | |
