0015263 | ParaView | Feature | public | 2015-01-14 12:50 | 2016-08-12 09:59 | ||||
Reporter | Julien Finet | ||||||||
Assigned To | Julien Finet | ||||||||
Summary | 0015263: Link FunctionalBagPlot view selection with Bag Chart view selection | ||||||||
Description | Points/Lines selected in one view should be also selected in the other view. | ||||||||
Steps To Reproduce | Load sineWaves.csv Create ExtractBagPlots filter and Apply. A functional bag view should be created. Turn the empty 3D view into a Bag plot view. Make ExtractBagPlots visible in bag plot view. Select points in bag plot view, it should select lines in functional bag view. Select lines in functional bag plot view, it should select points in bag view. | ||||||||
Project | Kitware | ||||||||
Topic Name | bag_plot | ||||||||
Type | usability | ||||||||
Attached Files | sineWaves.csv [^] (18,766 bytes) 2015-08-12 02:20 | ||||||||
(0034083) Julien Finet (developer) 2015-01-14 12:53 |
Show partial arrays of a block if it the only one selected If only one block is selected, it is ok to return the partial arrays. Change-Id: If0d9d5cd3e984b9620611d50179fb65e47c82a17 http://review.source.kitware.com/#/c/18256/ [^] Make ExtractBagPlot output one multiblock dataset Instead of 2 outputs, the filter's multiblock contains 2 blocks: the functional bag plot and the bag plot Change-Id: I6af0e7ee3c1c7318d8d282f3d022cc5101a2f69c http://review.source.kitware.com/#/c/18257/ [^] Add SELECTION_COLUMNS mode to Functional Bag chart Change-Id: I61edb420a92a97d9f666a0ae0a5e5d8c7c7bdde1 http://review.source.kitware.com/#/c/18258/ [^] Propagate SelectionColor to charts Change-Id: I58ecd9853c9720c16ddb1c004d84cfd0cc7dba0b http://review.source.kitware.com/#/c/18259/ [^] Add FunctionalBagPlots test Change-Id: I36f6ee209e1ec5910bf7174efe187a149d9ce51f http://review.source.kitware.com/#/c/18868/ [^] |
(0034966) Alan Scott (manager) 2015-08-11 19:16 |
Please attach sineWaves.csv Thanks! |
(0034969) Julien Finet (developer) 2015-08-12 02:21 |
sineWaves.csv is in ParaViewData http://www.paraview.org/files/ExternalData/MD5/13cae8b045a921b934eefc8dc40b8611 [^] |
(0035507) Alan Scott (manager) 2015-12-01 20:13 |
Rejecting this bug/feature. I did as described. When I rubber band selected points in the bag plots view, it works correctly. but, if the actual data in the bagplotview is smaller than the view (as it was for me), when you move the mouse up to do another selection, you get a output window with lots of verbiage. Looks like this: ERROR: In /projects/viz/paraview/src/ParaView/5.0.0-junk/ParaView4/VTK/Common/DataModel/vtkImageData.cxx, line 1391 vtkImageData (0x718a330): GetScalarPointer: Pixel (21, 100, 0) not in memory. Current extent= (0, 99, 0, 99, 0, 0) ERROR: In /projects/viz/paraview/src/ParaView/5.0.0-junk/ParaView4/VTK/Common/DataModel/vtkImageData.cxx, line 1391 vtkImageData (0x718a330): GetScalarPointer: Pixel (21, 100, 0) not in memory. Current extent= (0, 99, 0, 99, 0, 0) ERROR: In /projects/viz/paraview/src/ParaView/5.0.0-junk/ParaView4/VTK/Common/DataModel/vtkImageData.cxx, line 1391 vtkImageData (0x718a330): GetScalarPointer: Pixel (20, 100, 0) not in memory. Current extent= (0, 99, 0, 99, 0, 0) |
(0038760) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-01-14 12:50 | Julien Finet | New Issue | |
2015-01-14 12:50 | Julien Finet | Assigned To | => Julien Finet |
2015-01-14 12:50 | Julien Finet | Status | backlog => active development |
2015-01-14 12:51 | Julien Finet | Project | TBD => Kitware |
2015-01-14 12:51 | Julien Finet | Topic Name | => bag_plot |
2015-01-14 12:51 | Julien Finet | Type | feature => usability |
2015-01-14 12:53 | Julien Finet | Note Added: 0034083 | |
2015-04-23 03:26 | Julien Finet | Status | active development => gatekeeper review |
2015-04-23 03:26 | Julien Finet | Fixed in Version | => 4.5 |
2015-04-23 03:26 | Julien Finet | Resolution | open => fixed |
2015-06-02 08:45 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2015-06-02 08:45 | Utkarsh Ayachit | Fixed in Version | 4.5 => git-master |
2015-07-10 18:05 | Julien Finet | Steps to Reproduce Updated | |
2015-08-11 19:16 | Alan Scott | Note Added: 0034966 | |
2015-08-12 02:20 | Julien Finet | File Added: sineWaves.csv | |
2015-08-12 02:21 | Julien Finet | Note Added: 0034969 | |
2015-09-06 12:17 | Utkarsh Ayachit | Fixed in Version | git-master => 4.4 |
2015-12-01 20:13 | Alan Scott | Note Added: 0035507 | |
2015-12-01 20:13 | Alan Scott | Status | customer review => todo |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038760 | |
2016-08-12 09:59 | Kitware Robot | Status | todo => closed |
2016-08-12 09:59 | Kitware Robot | Fixed in Version | 4.4 => |
2016-08-12 09:59 | Kitware Robot | Resolution | fixed => moved |
