0015266 | ParaView | Bug | public | 2015-01-16 03:53 | 2016-08-12 09:59 | ||||
Reporter | Mathieu Rouillon | ||||||||
Platform | OS | Windows | OS Version | 8.1 | |||||
Product Version | 4.2 | ||||||||
Summary | 0015266: Problem saving point label format in selection display inspector window | ||||||||
Description | I change the default point label format %-#6.3g by %f and press the save current settings values as default button, but when I open a new paraview window the saving doesn't work (the default value is still here, not %f). The problem doesn't exist on Paraview 4.1 32-bit, win XP. I can do savings with Color Map Editor for example without any problem. How can I fix this? | ||||||||
Steps To Reproduce | - Open a vtu file - Press "select point on" button - Selection display inspector - Point labels : your variable - Edit selection label properties - Point label format : %f instead of default value %-#6.3g - Apply - Save current settings values as default button - Ok (at this step, everythin is ok) - Close the current vtu file - Open another vtu file - Press "select point on" button - Selection display inspector - Point labels : your variable --> the values you see are default point label format and not floating format | ||||||||
Additional Information | I don't know which project to choose... sorry. | ||||||||
Project | TBD | ||||||||
(0038761) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-01-16 03:53 | Mathieu Rouillon | New Issue | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038761 | |
