0015275 | ParaView | (No Category) | public | 2015-01-22 05:01 | 2016-08-12 09:59 | ||||
Reporter | Vadim SANDLER | ||||||||
Assigned To | Tristan Coulange | ||||||||
Priority | normal | Severity | minor | Reproducibility | unable to reproduce | ||||
Product Version | 4.2 | ||||||||
Summary | 0015275: Calculator filter grants forbidden calculation and do not prevent errors | ||||||||
Description | When using the calculator filter in ParaView, it has been noticed 2 issues : - forbidden calculations as /0, sqrt(negative number), ln(0)... return 0 value as a result which is not intuitive; - if we fill in a wrong formula, for instance cossin(my_field) or my_field**2, there is no warning or error message display. The "Result" field is simply not available which is, once more, not really intuitive. | ||||||||
Project | ParaViS | ||||||||
(0034308) Tristan Coulange (developer) 2015-03-16 10:39 |
Hello, Indeed for calculations like /0, sqrt(negative number), ln(0)... the filter returns 0 by default. But it can return another value thanks to the option "Replacement value", or display a warning if the option "Replace Invalid Results" is unchecked. These options are just below the buttons. The wrong formulas already display a warning. And for both cases, the new array generated has the suffix "(?)" to show that there was a problem. Feel free to tell me if I missed something. Tristan |
(0038763) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-01-22 05:01 | Vadim SANDLER | New Issue | |
2015-01-22 05:01 | Vadim SANDLER | Assigned To | => Tristan Coulange |
2015-03-16 10:39 | Tristan Coulange | Note Added: 0034308 | |
2015-03-16 10:40 | Tristan Coulange | Reproducibility | have not tried => unable to reproduce |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038763 | |
