0015289 | ParaView | (No Category) | public | 2015-01-27 09:57 | 2016-08-12 09:59 | ||||
Reporter | David Kramoliš | ||||||||
Product Version | 4.3 | ||||||||
Summary | 0015289: Load state function fails to load data (time) series, if the previous session is created with single data file | ||||||||
Description | When I tried to load save-state file (.pvsm), which was simply created from a session with single data file opened (tried .vtk and .csv) (no data series), and replaced original single data file with data series in selection form, paraview failed to correctly recognize that series was loaded (no indication of number of data/time steps and other related stuff). For the case with loading save-state file from previous session, where data series was loaded, the output is correct. Using Windows x64 build. | ||||||||
Project | Release | ||||||||
(0038767) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-01-27 09:57 | David Kramoliš | New Issue | |
2015-01-27 09:58 | David Kramoliš | Project | ParaViewPro => Release |
2015-01-27 10:00 | David Kramoliš | Description Updated | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038767 | |
