0015296 | ParaView | (No Category) | public | 2015-01-30 18:29 | 2016-08-12 09:59 | ||||
Product Version | 4.3 | ||||||||
Summary | 0015296: Load state fix paths dialog buttons don't work | ||||||||
Description | Create a state file. (Maybe put a sphere source in it). Load this state file. You will get a Fix Paths dialog box. There are two buttons at the bottom of the dialog - OK, and Close Without Saving. Neither one saves anything. So what is the Close Without Saving button suppose to do? If the OK should save the new paths, it isn't. Please fix it. | ||||||||
Project | Sandia | ||||||||
(0038770) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-01-30 18:29 | Alan Scott | New Issue | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038770 | |
