0015306ParaView(No Category)public2015-02-06 12:002015-09-06 12:17
ReporterUtkarsh Ayachit
Assigned ToUtkarsh Ayachit
StatusclosedResolutionfixed
PlatformOSOS Version
Product Version
Target Version4.4Fixed in Version4.4
Summary0015306: Add mechanism to "pick nearest point" on the surface
DescriptionParaView has mechanism to select points on surface, however, we need to draw a "box" enclosing the point of interest to select it. We should support selecting a nearest point.
TagsProbe/Picking Improvements
ProjectSandia
Topic Name
Typeincorrect functionality
 Relationships
related to 0010625closedUtkarsh Ayachit Selecting enhancements
  Notes
(0034525)
2015-06-09 11:29
commit e89e54b907180d32518f0727d30a6d3cd9a2f605
Date: Tue Jun 9 11:26:34 2015 -0400
    BUG 0015306: Add support for "radius" when click-selecting a point.
    Added a new advanced option on the "Settings | Render View" tab, named
    "Point Picking Radius" that can be used to specify a radius (in pixels)
    to use when click-selecting a point in the render view using "Select
    Points On". This radius is only used when you "click-to-select" or when
    using "interactive selection". Hence, if you click-n-drag to produce a
    sleecttion region, this radius won't be regarded since it's assumed that
    the user is indeed interested in selecting points only in that region.
(0034529)
2015-06-09 21:58
Merge request:
https://gitlab.kitware.com/paraview/paraview/merge_requests/153 [^]
(0034569)
Alan Scott (manager)
2015-06-16 19:17
Exquisite. Nice job.
Tested remote server, z_pinch1.exo.8, master, Linux.
 Issue History
2015-02-06 12:00 Utkarsh Ayachit New Issue
2015-02-06 12:00 Utkarsh Ayachit Tag Attached: Probe/Picking Improvements
2015-02-06 12:00 Utkarsh Ayachit Target Version => 4.4
2015-03-13 11:39 Utkarsh Ayachit Assigned To => Dan Lipsa
2015-06-07 14:33 Utkarsh Ayachit Assigned To Dan Lipsa =>
2015-06-07 14:33 Utkarsh Ayachit Status backlog => todo
2015-06-09 10:06 Utkarsh Ayachit Assigned To => Utkarsh Ayachit
2015-06-09 10:19 Utkarsh Ayachit Status todo => active development
2015-06-09 11:29 Utkarsh Ayachit Note Added: 0034525
2015-06-09 11:29 Utkarsh Ayachit Status active development => gatekeeper review
2015-06-09 11:29 Utkarsh Ayachit Resolution open => fixed
2015-06-09 21:58 Utkarsh Ayachit Status gatekeeper review => customer review
2015-06-09 21:58 Utkarsh Ayachit Fixed in Version => git-master
2015-06-09 21:58 Utkarsh Ayachit Note Added: 0034529
2015-06-16 19:17 Alan Scott Note Added: 0034569
2015-06-16 19:17 Alan Scott Status customer review => closed
2015-06-17 14:04 Alan Scott Relationship added related to 0010625
2015-09-06 12:17 Utkarsh Ayachit Fixed in Version git-master => 4.4
