0015331ParaView(No Category)public2015-02-19 07:032015-09-06 12:17
ReporterVadim SANDLER
Assigned ToTristan Coulange
StatusclosedResolutionfixed
PlatformOSOS Version
Product Version4.3
Target VersionFixed in Version4.4
Summary0015331: Regression of the animation from python
DescriptionScript demo.py works well in the ParaView-4.1 but doesn't work as expected in the ParaView-4.2 and ParaView-4.3.1
1) Modify the script demo.py from the archive demo.tag.gz (https://drive.google.com/file/d/0B_XAVXb9X2V8MXRmbEJHSldwbGc/view?usp=sharing [^]) in order to set correct path to the demo_*.vtm files.
2) Execute script in the ParaView python shell
In the the result the following errors are detected:
1) Presentation is not coloured by 'RESULT__DEPL____________________', 'Magnitude' array. It is coloured by this array after change component to 'DX' and to 'Magnitude' again on the 'Active Variable Controls' tool-bar.
2) Show animation view. The line for animation by WarpByVector1 'ScaleFactor' property with the Key Frames specified in the python script is not added to the animation view table.
It works well in the ParaView-4.1.
TagsNo tags attached.
ProjectParaViS
Topic Name0015331_fix_animation_track_python
Typeincorrect functionality
 Relationships
  Notes
(0034329)
Tristan Coulange (developer)
2015-03-27 04:13
Hello,
Regarding the first error, you have to add the following command at line 65:
  WarpByVectorDataRepresentation.RescaleTransferFunctionToDataRange(True)
It corresponds to the button "Rescale To Data Range" in the GUI. In the previous versions of ParaView it was done automatically, but now you will have to do it explicitly.
You can see it in the documentation "TheParaViewGuide-v4.3-CC-Edition.pdf", or by doing the same steps in the GUI with Python trace enabled: the generated trace has the command too.
Regarding the second error, it was fixed and merged into master:
https://gitlab.kitware.com/paraview/paraview/merge_requests/19#note_8369 [^]
Tristan
(0034732)
Alan Scott (manager)
2015-07-09 21:29
Closing bug report.
 Issue History
2015-02-19 07:03 Vadim SANDLER New Issue
2015-02-19 07:03 Vadim SANDLER Assigned To => Tristan Coulange
2015-03-26 02:47 Tristan Coulange Topic Name => 0015331_fix_animation_track_python
2015-03-26 02:47 Tristan Coulange Reproducibility have not tried => always
2015-03-26 02:47 Tristan Coulange Status backlog => active development
2015-03-27 04:13 Tristan Coulange Note Added: 0034329
2015-03-27 04:44 Tristan Coulange Status active development => gatekeeper review
2015-06-02 08:46 Utkarsh Ayachit Status gatekeeper review => customer review
2015-06-02 08:46 Utkarsh Ayachit Resolution open => fixed
2015-06-02 08:46 Utkarsh Ayachit Fixed in Version => git-master
2015-07-09 21:29 Alan Scott Note Added: 0034732
2015-07-09 21:29 Alan Scott Status customer review => closed
2015-09-06 12:17 Utkarsh Ayachit Fixed in Version git-master => 4.4
