0015348 | ParaView | (No Category) | public | 2015-02-27 08:25 | 2016-08-12 09:59 | ||||
Reporter | xgarnaud | ||||||||
Product Version | 4.3 | ||||||||
Summary | 0015348: error with the CGNSReader plugin | ||||||||
Description | I try to use Paraview 4.3 with the CGNSReader plugin The build process ends without error, the plugin loads but only the geometry is correctly loaded from the files. With the following changes < if (strcmp(location.c_str(), "Vertex") == 0) --- > if (location == "Vertex") 441c440 < else if (strcmp(location.c_str(), "CellCenter") == 0) --- > else if (location == "CellCenter") in Plugins/CGNSReader/cgio_helpers.cxx, and everything works fine. | ||||||||
Project | TBD | ||||||||
(0038782) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-02-27 08:25 | xgarnaud | New Issue | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038782 | |
