0015362 | ParaView | (No Category) | public | 2015-03-06 10:43 | 2016-08-12 09:59 | ||||
Reporter | Ben Boeckel (Kitware) | ||||||||
Assigned To | Scott Wittenburg | ||||||||
Summary | 0015362: Use higher port for web tests | ||||||||
Description | On my machine, I've been testing some web server stuff lately which uses port 8080. The web tests in ParaView use the same port and fail when they can't get it. Can they use a less common port to do testing so as not to collide with other things running on the machine? | ||||||||
Project | TBD | ||||||||
(0038783) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-03-06 10:43 | Ben Boeckel (Kitware) | New Issue | |
2015-03-06 10:43 | Ben Boeckel (Kitware) | Assigned To | => Scott Wittenburg |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038783 | |
