0015418 | ParaView | (No Category) | public | 2015-04-09 10:50 | 2016-08-12 09:59 | ||||
Reporter | Dan Lipsa | ||||||||
Summary | 0015418: Adding an empty selection clears selection | ||||||||
Description | 1. Open ParaViewData/Data/can.ex2 2. Click on Select Cells On (s) 3. Create a selection (click and drag to specify a rectangle) 4. Click on Select Cells on (s) 5. While pressing CTRL click and drag to specify a different selection. The cells in the new rectangle are added to the selection. 6. Repeat step 5. but specify a rectangle outside the dataset. The empty set should be added to the set of selected cells, so the selection should be unchanged. However, the selection is cleared. | ||||||||
Project | TBD | ||||||||
(0038801) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-04-09 10:50 | Dan Lipsa | New Issue | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038801 | |
