0015424 | ParaView | (No Category) | public | 2015-04-13 08:36 | 2016-08-12 09:59 | ||||
Reporter | David C. Lonie | ||||||||
Target Version | 5.1 | Fixed in Version | |||||||
Summary | 0015424: TileDisplay tests need some attention | ||||||||
Description | Some of the baselines are invalid and results aren't stable across platforms. The TileDisplay3DTesting-1x2 test has been disabled, as it was failing to recognize valid baselines in ExternalData. Something is very fishy about it. This should be fixed and re-enabled at some point. The remaining TileDisplay tests remain enabled. | ||||||||
Project | TBD | ||||||||
(0038805) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-04-13 08:36 | David C. Lonie | New Issue | |
2015-04-14 15:39 | David C. Lonie | Description Updated | |
2015-07-06 12:08 | David C. Lonie | Target Version | => 4.4 |
2015-09-11 16:43 | Utkarsh Ayachit | Target Version | 4.4 => 5.1 |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038805 | |
