0015429 | ParaView | (No Category) | public | 2015-04-22 05:06 | 2016-08-01 05:14 | ||||
Reporter | Vadim SANDLER | ||||||||
Assigned To | Mathieu Westphal | ||||||||
Product Version | 4.3 | ||||||||
Target Version | Fixed in Version | 5.1 | |||||||
Summary | 0015429: Plot Matrix View is not working and causes a crash of ParaView | ||||||||
Description | 1) Open attached file data.csv, click Apply on the "Properties" panel. 2) Create "Plot Matrix View" and display data in created view. 3) Try to select points on two or three different plots on the "Plot Matrix View" in the random order, as shown on attached picture PlotMatrix.png. As a result after 5-10 click (sometimes less) application crashes. | ||||||||
Project | ParaViS | ||||||||
Attached Files | data.csv [^] (2,791 bytes) 2015-04-22 05:06 PlotMatrix.png [^] (124,399 bytes) 2015-04-22 05:07 data.csv.png [^] (121,846 bytes) 2016-01-28 03:34 | ||||||||
Relationships | ||||||
(0035053) Mathieu Westphal (developer) 2015-08-25 05:56 |
Do you also have these kinds of error before segfaulting ? ERROR: In /home/glow/work/kitware/paraview/paraview/VTK/Rendering/ContextOpenGL/vtkOpenGLContextDevice3D.cxx, line 330 vtkOpenGLContextDevice3D (0x43b6a30): failed after PushMatrix 1 OpenGL errors detected 0 : (1283) Stack overflow may be related to: http://www.paraview.org/Bug/bug_relationship_graph.php?bug_id=14553&graph=dependency [^] http://www.paraview.org/Bug/view.php?id=14661 [^] |
(0035082) Vadim SANDLER (reporter) 2015-08-27 09:53 |
No, in terminal we can only see: Segmentation fault (core dumped) paraview |
(0035177) Mathieu Westphal (developer) 2015-09-08 06:03 |
Associated VTK issue : http://www.vtk.org/Bug/view.php?id=15708 [^] Fixed by: https://gitlab.kitware.com/vtk/vtk/merge_requests/635 [^] |
(0035548) Alan Scott (manager) 2015-12-11 21:53 |
Looks stable to me. I tried about 20 to 30 random selections. If a crash is found, be sure to explain exactly how to replicate it. Tested master, Linux, local server. |
(0035687) Vadim SANDLER (reporter) 2016-01-28 03:34 |
This bug is reproduced on ParaView-5.0.0 version in case if it is executed in the client-server mode, steps to reproduce: 1) Run pvserver: pvserver --multi-clients --server-port=11111 --use-offscreen-rendering& 2) Run paraview 3) Connect to pvserver 4) Load data.csv file 5) Create Plot Matrix View 6) Display data in the created view 7) Click on the plot item from the left column which is located in the "Data C" row, as shown on the data.csv.picture. => Crash |
(0035688) Mathieu Westphal (developer) 2016-01-28 03:45 edited on: 2016-01-28 05:19 |
indeed. reproduced. |
(0035689) Vadim SANDLER (reporter) 2016-01-28 05:07 |
Seems the reason of the bug is "--multi-clients" option of pvserver. Without this option selection and animation work well. |
(0035690) Mathieu Westphal (developer) 2016-01-28 05:18 |
hum, i reproduce the error without the "--multi-clients", and already identified the cause of the error, so i'm not sure about that. |
(0036650) Mathieu Westphal (developer) 2016-08-01 05:13 |
https://gitlab.kitware.com/paraview/paraview/merge_requests/768 [^] |
2015-04-22 05:06 | Vadim SANDLER | New Issue | |
2015-04-22 05:06 | Vadim SANDLER | Assigned To | => Tristan Coulange |
2015-04-22 05:06 | Vadim SANDLER | File Added: data.csv | |
2015-04-22 05:07 | Vadim SANDLER | File Added: PlotMatrix.png | |
2015-08-25 05:56 | Mathieu Westphal | Note Added: 0035053 | |
2015-08-27 09:53 | Vadim SANDLER | Note Added: 0035082 | |
2015-09-08 06:03 | Mathieu Westphal | Note Added: 0035177 | |
2015-09-08 06:04 | Mathieu Westphal | Status | backlog => gatekeeper review |
2015-09-08 06:04 | Mathieu Westphal | Resolution | open => fixed |
2015-09-17 05:36 | Joachim Pouderoux | Assigned To | Tristan Coulange => Mathieu Westphal |
2015-12-11 15:01 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2015-12-11 15:01 | Utkarsh Ayachit | Fixed in Version | => 5.0 |
2015-12-11 21:53 | Alan Scott | Note Added: 0035548 | |
2015-12-11 21:53 | Alan Scott | Status | customer review => closed |
2016-01-28 03:34 | Vadim SANDLER | Note Added: 0035687 | |
2016-01-28 03:34 | Vadim SANDLER | Status | closed => backlog |
2016-01-28 03:34 | Vadim SANDLER | Resolution | fixed => reopened |
2016-01-28 03:34 | Vadim SANDLER | File Added: data.csv.png | |
2016-01-28 03:45 | Mathieu Westphal | Note Added: 0035688 | |
2016-01-28 03:46 | Mathieu Westphal | Note Edited: 0035688 | |
2016-01-28 05:07 | Vadim SANDLER | Note Added: 0035689 | |
2016-01-28 05:18 | Mathieu Westphal | Note Added: 0035690 | |
2016-01-28 05:19 | Mathieu Westphal | Note Edited: 0035688 | |
2016-03-29 09:05 | Mathieu Westphal | Status | backlog => gatekeeper review |
2016-03-29 09:05 | Mathieu Westphal | Resolution | reopened => fixed |
2016-03-29 09:06 | Mathieu Westphal | Status | gatekeeper review => backlog |
2016-03-29 09:06 | Mathieu Westphal | Resolution | fixed => reopened |
2016-05-11 10:13 | Mathieu Westphal | Note Added: 0035948 | |
2016-05-11 10:13 | Mathieu Westphal | Status | backlog => gatekeeper review |
2016-05-11 10:13 | Mathieu Westphal | Resolution | reopened => fixed |
2016-05-11 10:17 | Mathieu Westphal | Relationship added | related to 0016118 |
2016-06-17 00:05 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2016-06-17 00:05 | Utkarsh Ayachit | Fixed in Version | 5.0 => 5.1 |
2016-08-01 05:13 | Mathieu Westphal | Note Added: 0036650 | |
2016-08-01 05:13 | Mathieu Westphal | Status | customer review => gatekeeper review |
2016-08-01 05:13 | Mathieu Westphal | Note Deleted: 0035948 | |
2016-08-01 05:14 | Mathieu Westphal | Status | gatekeeper review => customer review |
2016-08-01 05:14 | Mathieu Westphal | Status | customer review => closed |
