0015430 | ParaView | (No Category) | public | 2015-04-22 07:40 | 2015-12-01 20:18 | ||||
Reporter | Vadim SANDLER | ||||||||
Assigned To | Mathieu Westphal | ||||||||
Product Version | 4.3 | ||||||||
Target Version | Fixed in Version | 5.0 | |||||||
Summary | 0015430: Error messages are not displayed in the ParaView output window in case if pvserver is executed in the multi-clients mode | ||||||||
Description | - Run 'pvserver --multi-clients' command. - Start ParaView and connect to the pvserver. - Open any corrupted file. => nothing happens, but if the pvserver is executed without --multi-clients option, then error message is displayed in the 'Output Window'. Is it possible activate such useful functionality in the multi-clients mode? | ||||||||
Project | ParaViS | ||||||||
(0035052) Mathieu Westphal (developer) 2015-08-25 05:45 |
One client should not see error of another client. This may prove difficult to implement. |
(0035061) Vadim SANDLER (reporter) 2015-08-25 12:12 |
Dear Mathieu, I understand that it might be difficult to implement the possibility to dispatch errors separately to all clients. But maybe it is at least possible to avoid blocking reporting errors in "multi-client" mode - one can imagine some option which, when switched ON, forces server to send errors to all attached clients. It might be a quick solution. Regards, Vadim. |
(0035230) Mathieu Westphal (developer) 2015-09-18 09:15 |
Fixed by: https://gitlab.kitware.com/paraview/paraview/merge_requests/384 [^] Master Client will now receive error and progress from server. |
(0035238) Utkarsh Ayachit (administrator) 2015-09-23 08:52 |
Merged using: https://gitlab.kitware.com/paraview/paraview/merge_requests/388 [^] |
(0035509) Alan Scott (manager) 2015-12-01 20:18 |
Closing untested. |
2015-04-22 07:40 | Vadim SANDLER | New Issue | |
2015-04-22 07:40 | Vadim SANDLER | Assigned To | => Tristan Coulange |
2015-08-25 05:45 | Mathieu Westphal | Note Added: 0035052 | |
2015-08-25 12:12 | Vadim SANDLER | Note Added: 0035061 | |
2015-09-18 09:15 | Mathieu Westphal | Note Added: 0035230 | |
2015-09-18 09:15 | Mathieu Westphal | Assigned To | Tristan Coulange => Mathieu Westphal |
2015-09-18 09:15 | Mathieu Westphal | Status | backlog => gatekeeper review |
2015-09-18 09:15 | Mathieu Westphal | Resolution | open => fixed |
2015-09-18 09:15 | Mathieu Westphal | Fixed in Version | => 5.0 |
2015-09-23 08:52 | Utkarsh Ayachit | Note Added: 0035238 | |
2015-09-23 08:52 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2015-12-01 20:18 | Alan Scott | Note Added: 0035509 | |
2015-12-01 20:18 | Alan Scott | Status | customer review => closed |
