0015432 | ParaView | (No Category) | public | 2015-04-23 04:08 | 2015-12-01 17:18 | ||||
Reporter | Vadim SANDLER | ||||||||
Assigned To | Mathieu Westphal | ||||||||
Product Version | 4.3 | ||||||||
Summary | 0015432: Feature: Define default representation mode via ParaView settings | ||||||||
Description | At the moment in the ParaView default representation is 'Surface' and it can't be customized. An aim of this improvement is adding in the ParaView settings default representation mode (drop-down list for example, which will contain 'Points', 'Wireframe', 'Surface', ..., etc.). This representation should be applied to the newly created presentations. | ||||||||
Project | ParaViS | ||||||||
Type | feature | ||||||||
(0035050) Mathieu Westphal (developer) 2015-08-25 05:29 |
the default representation is surface only for certain type of dataset, it can be sometime outline or even slice see ./ParaViewCore/ServerManager/Rendering/vtkSMRepresentationTypeDomain.cxx We could modify the default rep, when not in particular case. |
(0035093) Vadim SANDLER (reporter) 2015-08-28 04:47 |
OK, let's drop the idea of a preference for the default representation since it is a little bit complicated. You can close this issue. |
(0035500) Alan Scott (manager) 2015-12-01 17:18 |
As per reporter, closing bug. |
2015-04-23 04:08 | Vadim SANDLER | New Issue | |
2015-04-23 04:08 | Vadim SANDLER | Assigned To | => Tristan Coulange |
2015-08-25 05:29 | Mathieu Westphal | Note Added: 0035050 | |
2015-08-25 05:29 | Mathieu Westphal | Assigned To | Tristan Coulange => Mathieu Westphal |
2015-08-25 05:29 | Mathieu Westphal | Status | backlog => todo |
2015-08-28 04:47 | Vadim SANDLER | Note Added: 0035093 | |
2015-09-03 05:39 | Mathieu Westphal | Status | todo => gatekeeper review |
2015-09-03 05:39 | Mathieu Westphal | Resolution | open => won't fix |
2015-09-03 09:42 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2015-12-01 17:18 | Alan Scott | Note Added: 0035500 | |
2015-12-01 17:18 | Alan Scott | Status | customer review => closed |
