0015443 | ParaView | (No Category) | public | 2015-05-01 15:24 | 2016-08-12 09:59 | ||||
Summary | 0015443: Volume rendering non first block fails | ||||||||
Description | You can only volume render the first block of a multi-block dataset. This is a bug, and desperately needs to be fixed. * Linux, master, local server. * Open can.exo. All variables on. Turn off the first block (leaving the second block, the plate, turned on). Apply. * Volume render. <<Bug>> You will see lots of warnings, and nothing gets volume rendered. Without tricks, this makes volume rendering non first blocks impossible. This is version 4.4.0-junk of ParaView. PV_INSTALL_DIR is /projects/viz/paraview/ParaView/4.4.0-junk/Linux-eng-sci-rhel6-x86_64 [1] 28584 ERROR: In /projects/viz/paraview/src/ParaView/4.4.0-junk/ParaView4/VTK/Common/DataModel/vtkDataObjectTree.cxx, line 318 vtkMultiBlockDataSet (0x6305920): Invalid iterator location. ERROR: In /projects/viz/paraview/src/ParaView/4.4.0-junk/ParaView4/ParaViewCore/VTKExtensions/Rendering/vtkVolumeRepresentationPreprocessor.cxx, line 75 vtkVolumeRepresentationPreprocessor (0x6271a00): Could not extract a dataset from multiblock input. ERROR: In /projects/viz/paraview/src/ParaView/4.4.0-junk/ParaView4/VTK/Common/ExecutionModel/vtkExecutive.cxx, line 784 vtkCompositeDataPipeline (0x62805c0): Algorithm vtkVolumeRepresentationPreprocessor(0x6271a00) returned failure for request: vtkInformation (0x5937030) Debug: Off Modified Time: 386168 Reference Count: 1 Registered Events: (none) Request: REQUEST_DATA FORWARD_DIRECTION: 0 FROM_OUTPUT_PORT: 0 ALGORITHM_AFTER_FORWARD: 1 | ||||||||
Project | Sandia | ||||||||
(0038810) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-05-01 15:24 | Alan Scott | New Issue | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038810 | |
