0015446 | ParaView | (No Category) | public | 2015-05-02 16:17 | 2016-08-12 09:59 | ||||
Reporter | Jan Brezina | ||||||||
Product Version | 4.3 | ||||||||
Summary | 0015446: calling IntegrateVariables from python leads to infinite recursion | ||||||||
Description | I want to apply a pipeline ending with IntegrateVariables to series of data. In order to free memory I decidede to diconnect form server after processing a single data. However with such setup IntegrateVariables end in infinite recursion, reporting: Exception RuntimeError: 'maximum recursion depth exceeded while calling a Python object' in <bound method IntegrateVariables.__del__ of <paraview.servermanager.IntegrateVariables object at 0x39ecb90>> I can reproduce this behaviour calling following script with pvpython: from paraview import servermanager servermanager.Connect() frac = servermanager.sources.HierarchicalFractal() iv = servermanager.filters.IntegrateVariables(frac) servermanager.Disconnect() I finally succeed with workaround that use ProgrammableFilter calling vtkIntegrateAttributes directly. Jan | ||||||||
Project | TBD | ||||||||
(0038811) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-05-02 16:17 | Jan Brezina | New Issue | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038811 | |
