0015463 | ParaView | (No Category) | public | 2015-05-08 17:14 | 2016-08-12 09:59 | ||||
Product Version | 4.3 | ||||||||
Summary | 0015463: Plot selection over time broken for frozen selection | ||||||||
Description | I noticed that when you do a query, then freeze the selection, and then plot the selection over time, the plot does not work. To replicate, do the following. 1. Open can.ex2. Load all Variables. Apply. 2. Go to last time step. 3. Open Find Data dialog box. 4. Run a selection where EQPS is max. (Cell 3486 should get selected.) 5. Click Freeze Selection in the Find Data dialog box. 6. Click Plot Selection Over Time in the Find Data dialog box. 7. Click Apply in the Properties panel. At this point, nothing gets plotted. Note that if you skip step 5, you go get a correct (albeit different) plot. | ||||||||
Project | TBD | ||||||||
(0038820) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-05-08 17:14 | Ken Moreland | New Issue | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038820 | |
