0015490 | ParaView | (No Category) | public | 2015-05-27 04:12 | 2015-09-06 12:18 | ||||
Reporter | Mathieu Westphal | ||||||||
Assigned To | Mathieu Westphal | ||||||||
Priority | urgent | Severity | minor | Reproducibility | have not tried | ||||
Product Version | 4.3 | ||||||||
Target Version | Fixed in Version | 4.4 | |||||||
Summary | 0015490: Modify server launcher and server configuration interface to allow reuse from plugin | ||||||||
Description | A Client requested a plugin to do very specific server connexion using slurm. In order to achieve that it is necessary to open the server launcher and configuration interface. | ||||||||
Project | TBD | ||||||||
Type | feature | ||||||||
(0034424) Mathieu Westphal (developer) 2015-05-27 04:22 edited on: 2015-05-27 04:22 |
Merge Request 124 ยท created by Mathieu Westphal: Slurm plugin patch A Client requested a plugin to do very specific server connexion using slurm. In order to achieve that it is necessary to open the server launcher and configuration interface. The modifications are as following : Make some methods from pqServerConnectDialog virtual so they can be redefined in inherited class Move all unnamed namespace declared class and methods from pqServerLauncher to pqServerConfiguration, and make these methods public so they can be used from a class handling pqServerConfiguration. Mode pqServerFileChooser from Components to Core, so it can be used by the precedent methods. Move the regexp command expand to command method so command method can generate an expended command if necessary. https://gitlab.kitware.com/paraview/paraview/merge_requests/124 [^] [^] [^] |
(0034512) Mathieu Westphal (developer) 2015-06-05 08:57 |
Finally done in https://gitlab.kitware.com/paraview/paraview/merge_requests/125 [^] |
(0034513) Mathieu Westphal (developer) 2015-06-05 08:57 |
2015-05-27 04:12 | Mathieu Westphal | New Issue | |
2015-05-27 04:12 | Mathieu Westphal | Assigned To | => Utkarsh Ayachit |
2015-05-27 04:14 | Mathieu Westphal | Description Updated | |
2015-05-27 04:22 | Mathieu Westphal | Note Added: 0034424 | |
2015-05-27 04:22 | Mathieu Westphal | Note Edited: 0034424 | |
2015-06-05 08:57 | Mathieu Westphal | Note Added: 0034512 | |
2015-06-05 08:57 | Mathieu Westphal | Note Added: 0034513 | |
2015-06-05 08:57 | Mathieu Westphal | Status | backlog => gatekeeper review |
2015-06-05 08:57 | Mathieu Westphal | Fixed in Version | => git-master |
2015-06-05 08:57 | Mathieu Westphal | Resolution | open => fixed |
2015-06-05 08:58 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2015-06-05 08:58 | Utkarsh Ayachit | Assigned To | Utkarsh Ayachit => Mathieu Westphal |
2015-06-05 08:59 | Utkarsh Ayachit | Status | customer review => closed |
2015-09-06 12:18 | Utkarsh Ayachit | Fixed in Version | git-master => 4.4 |
