0015510 | ParaView | (No Category) | public | 2015-06-04 07:10 | 2016-08-12 09:59 | ||||
Reporter | Mathieu Westphal | ||||||||
Target Version | 5.1 | Fixed in Version | |||||||
Summary | 0015510: Python Annotation Filter in custom filter generate table | ||||||||
Description | (Git master versin, as well in 4.3.1) Putting an Python Annotation Filter in a custom filter, then using this new custom filter will only generate table data. How to reproduce: Create a source Add a python annotation , using "Test" as a expression, Apply Create a custom filter with the python annotation filter Add the new custom filter to the source, Apply What is seen: A new spreadsheet view open showing the "Test" data, the icon of the custom filter is a table What is expected: Th render view should show a "Test" Annotation, the custom filter icon should be a "green cube" like standard filter. | ||||||||
Project | TBD | ||||||||
(0038829) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-06-04 07:10 | Mathieu Westphal | New Issue | |
2015-06-04 07:10 | Mathieu Westphal | Assigned To | => Utkarsh Ayachit |
2015-06-04 11:58 | Utkarsh Ayachit | Target Version | => 4.4 |
2015-08-13 10:41 | Mathieu Westphal | Description Updated | |
2015-09-11 16:43 | Utkarsh Ayachit | Target Version | 4.4 => 5.1 |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038829 | |
