0015511 | ParaView | (No Category) | public | 2015-06-04 13:02 | 2016-08-12 09:59 | ||||
Target Version | 5.1 | Fixed in Version | |||||||
Summary | 0015511: Rubber band selections are missing visible points/nodes | ||||||||
Description | Rubber band selections are missing some visible points/ nodes. Replicate as follows: * Linux, master, local server. * Open quadraticTetra01.vtu (from the ParaView data). All vars on. Apply. * -Z * Now, rubber band select all of the objects (Select Points On). <<Bug>> Some points were not selected. Specifically, the top point on the left object, as well as most of the points on the middle (2d) object. If you change views (i.e., +Z), different points get missed... | ||||||||
Project | Sandia | ||||||||
(0038830) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-06-04 13:02 | Alan Scott | New Issue | |
2015-07-08 14:43 | Alan Scott | Target Version | => 4.5 |
2015-09-11 16:44 | Utkarsh Ayachit | Target Version | 4.5 => 5.1 |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038830 | |
