0015571 | ParaView | (No Category) | public | 2015-07-07 15:24 | 2016-08-12 09:59 | ||||
Target Version | 5.1 | Fixed in Version | |||||||
Summary | 0015571: Multi-block inspector, color and opacity messed up. | ||||||||
Description | Master, Linux, local server. Here are instructions from a user. I had to follow them exactly to show the bug. * Load bake.e * Accept default color by solid color * Go down properties panel to find Styling panel and reduce opacity to 0000068:0000050% * Now color by ObjectId – this works * Return opacity to 100% and return to default color by solid color * Go into Multi-block inspector and right-click Element Blocks – reduce opacity to 0000068:0000050% Note that this bug only shows if you are selecting "Element Blocks" - if you select one single block the bug does not show. * Now color by ObjectId – this doesn’t work * Unset Opacity in Multi-block inspector and coloring returns * It appears that reducing opacity to less than 100% in Multi-block inspector disables coloring of object – this substantially reduces capability since adjusting opacity per block is not available in the Properties panel. Utkarsh has bake.e. | ||||||||
Project | Sandia | ||||||||
(0034712) Dan Lipsa (developer) 2015-07-08 22:58 edited on: 2015-07-08 23:23 |
Another way to get the bug: Load bake.e Set both color and opacity through a color map (for instance ObjectId). When you set a block color through the Multi-block inspector the opacity is also set to the actor's opacity (instead of staying set through the color map). Similarily, when you set a block opacity through the Multi-block inspector the color is also set to the actor's color (instead of staying set through the color map). This seems to be a bug in vtkCompositePainter and/or vtkOpenGLCompositePainter |
(0034720) Dan Lipsa (developer) 2015-07-09 11:04 edited on: 2015-07-09 16:37 |
For OpenGL2 as of 27ec7553b043d244b7199c2947b2a653b9436422 (Jul 9th). Setting the opacity through the Multi-block inspector works for both color mapping and solid color. Setting the color through the Multi-block inspector works only for solid color. |
(0034807) Utkarsh Ayachit (administrator) 2015-07-20 10:57 |
This issues has been fixed entire for OpenGL2 backend. Setting opacity as well as color through Multiblock inspector when using scalar coloring works as expected. |
(0034902) Alan Scott (manager) 2015-08-05 22:18 |
If this is fixed in OGL2, I would be OK not fixing it for 4.4. Thoughts? |
(0034903) Cory Quammen (developer) 2015-08-06 01:50 |
It doesn't make sense to spend the time to fix the OpenGL backend, IMHO. |
(0034907) Utkarsh Ayachit (administrator) 2015-08-06 14:26 |
Yes, Alan and I already agreed on not fixing it for OpenGL1 and closing this bug once OpenGL2 backend becomes default in ParaView and this can be easily tested. |
(0034908) Alan Scott (manager) 2015-08-06 15:14 |
Lets close this bug when we get to OGL 2. Setting for PV 4.5, so that I actually test it. |
(0038842) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-07-07 15:24 | Alan Scott | New Issue | |
2015-07-07 15:24 | Alan Scott | Target Version | => 4.4 |
2015-07-07 15:25 | Alan Scott | Description Updated | |
2015-07-07 15:25 | Utkarsh Ayachit | Assigned To | => Dan Lipsa |
2015-07-08 16:35 | Dan Lipsa | Status | backlog => active development |
2015-07-08 16:36 | Utkarsh Ayachit | Status | active development => todo |
2015-07-08 22:58 | Dan Lipsa | Note Added: 0034712 | |
2015-07-08 22:59 | Dan Lipsa | Note Edited: 0034712 | |
2015-07-08 23:00 | Dan Lipsa | Note Edited: 0034712 | |
2015-07-08 23:02 | Dan Lipsa | Note Edited: 0034712 | |
2015-07-08 23:21 | Dan Lipsa | Status | todo => active development |
2015-07-08 23:22 | Dan Lipsa | Note Edited: 0034712 | |
2015-07-08 23:23 | Dan Lipsa | Note Edited: 0034712 | |
2015-07-09 11:04 | Dan Lipsa | Note Added: 0034720 | |
2015-07-09 16:37 | Dan Lipsa | Note Edited: 0034720 | |
2015-07-09 16:38 | Dan Lipsa | Assigned To | Dan Lipsa => |
2015-07-09 16:38 | Dan Lipsa | Status | active development => todo |
2015-07-20 10:57 | Utkarsh Ayachit | Note Added: 0034807 | |
2015-08-05 22:18 | Alan Scott | Note Added: 0034902 | |
2015-08-06 01:50 | Cory Quammen | Note Added: 0034903 | |
2015-08-06 14:26 | Utkarsh Ayachit | Note Added: 0034907 | |
2015-08-06 15:13 | Alan Scott | Assigned To | => Alan Scott |
2015-08-06 15:14 | Alan Scott | Note Added: 0034908 | |
2015-08-06 15:14 | Alan Scott | Status | todo => backlog |
2015-08-06 15:14 | Alan Scott | Target Version | 4.4 => 4.5 |
2015-08-06 15:15 | Alan Scott | Assigned To | Alan Scott => |
2015-09-11 16:44 | Utkarsh Ayachit | Target Version | 4.5 => 5.1 |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038842 | |
