0015572ParaView(No Category)public2015-07-08 10:062016-08-12 09:59
ReporterMo Sha
Assigned ToKitware Robot
StatusclosedResolutionmoved
PlatformOSOS Version
Product Version4.3
Summary0015572: Paraview Python Shell canot create an instance of multiprocessing.Pool
DescriptionIn order to use multi-core cpu, i try to create a multiprocessing.Pool instance for multi-processing programming. And the pvpython will crash immediately when creating multiprocessing.Pool instance as followed:
import multiprocessing
pool = multiprocessing.Pool(process=4)
Process PoolWorker-1:
Process PoolWorker-2:
Traceback (most recent call last):
paraview: Fatal IO error 2 (No such file or directory) on X server :0.
Process PoolWorker-3:
paraview: Fatal IO error 11 (Resource temporarily unavailable) on X server :0.
Process PoolWorker-4:
[xcb] Unknown sequence number while processing queue
[xcb] Most likely this is a multi-threaded client and XInitThreads has not been called
[xcb] Aborting, sorry about that.
paraview: ../../src/xcb_io.c:274: poll_for_event: Assertion `!xcb_xlib_threads_sequence_lost' failed.
Aborted (core dumped)
TagsNo tags attached.
ProjectRelease
Topic Name
Typecrash
 Relationships
  Notes
(0038843)
Kitware Robot (administrator)
2016-08-12 09:59
Resolving issue as `moved`.
 Issue History
2015-07-08 10:06 Mo Sha New Issue
2016-08-12 09:59 Kitware Robot Note Added: 0038843
2016-08-12 09:59 Kitware Robot Status backlog => closed
2016-08-12 09:59 Kitware Robot Resolution open => moved
2016-08-12 09:59 Kitware Robot Assigned To => Kitware Robot
