0015577 | ParaView | (No Category) | public | 2015-07-09 18:06 | 2015-09-06 12:17 | ||||
Target Version | 4.4 | Fixed in Version | 4.4 | ||||||
Summary | 0015577: Copy paste filters doesn't work | ||||||||
Description | * Linux, master, local server. * Can.exo, all vars on, apply. * plot over line. Apply. Turn off VEL_Magnitude. * Highlight the can.exo again in the pipeline browser. * Plot over line. Apply. * Right click on the first plot over line, select copy. * Right click on the second plot over line, select paste. The VEL_Magnitude doesn't turn off. What appears to not work plot over line: Variable selection, variable color, line thickness, Chart Axis, you get the point. | ||||||||
Project | Sandia | ||||||||
(0034729) Alan Scott (manager) 2015-07-09 18:07 |
This one is very important for my user (Venus). Please talk to Utkarsh or me if it ends up being a major issue, and we will defer to 4.5. |
(0034739) Utkarsh Ayachit (administrator) 2015-07-10 10:18 |
FYI, Copy/Paste was only designed to operate on the Filter/Source properties not display properties. I believe we can extend that to include display properties too. Should that be a separate option? What if the user only want to copy filter properties and not display properties or vice versa? |
(0034750) Alan Scott (manager) 2015-07-10 18:55 |
Had to think about it. :-) In my mind, your question comes from a programmer's perspective. However, think like a user. I copy the state contained in the container called a filter, I paste the state into another container called a filter. What state should be copied for the whole filter? All of the state. I feel this is sufficient granularity. If a user wants persistent state between calls, that's what the save properties is for. |
(0034850) Utkarsh Ayachit (administrator) 2015-07-29 13:15 |
Merge request: https://gitlab.kitware.com/paraview/paraview/merge_requests/256 [^] |
(0034851) Utkarsh Ayachit (administrator) 2015-07-29 13:17 |
The Properties Panel now has copy/paste buttons next to the headers for source "Properties", "Display" and "View". Users can use that to copy/paste values for the 3 entities separately. The "Copy/Paste" context menu still only copies the source Properties. We can remove that entirely, to avoid the confusion. |
(0034868) Utkarsh Ayachit (administrator) 2015-08-01 21:01 |
merged in master. |
(0034881) Alan Scott (manager) 2015-08-04 21:06 |
Perfect!!!! Tested master, Linux, remote server. |
2015-07-09 18:06 | Alan Scott | New Issue | |
2015-07-09 18:07 | Alan Scott | Note Added: 0034729 | |
2015-07-09 18:07 | Alan Scott | Status | backlog => todo |
2015-07-09 18:07 | Alan Scott | Product Version | => git-master |
2015-07-09 18:07 | Alan Scott | Target Version | => 4.4 |
2015-07-10 10:18 | Utkarsh Ayachit | Note Added: 0034739 | |
2015-07-10 18:55 | Alan Scott | Note Added: 0034750 | |
2015-07-23 15:29 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2015-07-27 14:39 | Utkarsh Ayachit | Status | todo => active development |
2015-07-29 13:15 | Utkarsh Ayachit | Note Added: 0034850 | |
2015-07-29 13:15 | Utkarsh Ayachit | Status | active development => gatekeeper review |
2015-07-29 13:15 | Utkarsh Ayachit | Resolution | open => fixed |
2015-07-29 13:17 | Utkarsh Ayachit | Note Added: 0034851 | |
2015-08-01 21:01 | Utkarsh Ayachit | Note Added: 0034868 | |
2015-08-01 21:01 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2015-08-01 21:01 | Utkarsh Ayachit | Fixed in Version | => git-master |
2015-08-04 21:06 | Alan Scott | Note Added: 0034881 | |
2015-08-04 21:06 | Alan Scott | Status | customer review => closed |
2015-09-06 12:17 | Utkarsh Ayachit | Fixed in Version | git-master => 4.4 |
