0015597 | ParaView | (No Category) | public | 2015-07-24 18:34 | 2015-09-06 12:17 | ||||
Target Version | 4.4 | Fixed in Version | 4.4 | ||||||
Summary | 0015597: Iterative select cells on - Clear Selection fails | ||||||||
Description | * Linux, master, local server * Wavelet. Apply. Surface with Edges. * Iterative select cells on. Now, try to clear the selection. The icon is not active. | ||||||||
Project | Sandia | ||||||||
(0034821) Alan Scott (manager) 2015-07-24 18:36 |
Adding to 4.4, since this is new functionality, and should work properly. |
(0034823) Utkarsh Ayachit (administrator) 2015-07-27 11:16 |
Alan, This is not a bug. You haven't made a "permanent" selection until you've clicked somewhere. That's why the icon is disabled. As soon as you click a on a cell to "mark" it, the icon becomes enabled and I tested that you can indeed click it to clear the selection. |
(0034835) Alan Scott (manager) 2015-07-27 20:18 |
Makes sense. I incorrectly reported this as a bug. Closing. |
2015-07-24 18:34 | Alan Scott | New Issue | |
2015-07-24 18:35 | Alan Scott | Status | backlog => todo |
2015-07-24 18:35 | Alan Scott | Target Version | => 4.4 |
2015-07-24 18:35 | Alan Scott | Description Updated | |
2015-07-24 18:36 | Alan Scott | Note Added: 0034821 | |
2015-07-27 11:16 | Utkarsh Ayachit | Note Added: 0034823 | |
2015-07-27 11:16 | Utkarsh Ayachit | Status | todo => customer review |
2015-07-27 11:16 | Utkarsh Ayachit | Fixed in Version | => git-master |
2015-07-27 11:16 | Utkarsh Ayachit | Resolution | open => won't fix |
2015-07-27 11:16 | Utkarsh Ayachit | Assigned To | => Utkarsh Ayachit |
2015-07-27 20:18 | Alan Scott | Note Added: 0034835 | |
2015-07-27 20:18 | Alan Scott | Status | customer review => closed |
2015-09-06 12:17 | Utkarsh Ayachit | Fixed in Version | git-master => 4.4 |
