0015600 | ParaView | (No Category) | public | 2015-07-28 13:59 | 2015-12-01 19:38 | ||||
Assigned To | David C. Lonie | ||||||||
Target Version | Fixed in Version | 4.4 | |||||||
Summary | 0015600: Tracing doesn't trace cameras for multiple views correctly | ||||||||
Description | Tracing doesn't trace cameras for multiple views correctly | ||||||||
Project | ERDC | ||||||||
(0035033) David C. Lonie (developer) 2015-08-19 13:04 |
This appears to be functioning correctly. Only views that have changes will have their camera state exported in the trace. For instance: Single scene, no changes between start/stop trace -- no camera info in trace. Construct two scenes by viewing Wavelet from multiple angles while tracing -- both cameras in trace. Create 4 views of a scene, start tracing, modify view #3, stop tracing -- only view #3's camera is traced. Also tested the Catalyst CoProcessing >> Export State mechanism, and it appears to output all camera states correctly. |
(0035504) Alan Scott (manager) 2015-12-01 19:38 |
As stated by David, this appears to be working. Note that cameras aren't output until you actually stop trace. This may be a bug, but I believe isn't this bug. Tested 4.4.0, Linux, local server. |
2015-07-28 13:59 | Utkarsh Ayachit | New Issue | |
2015-08-19 13:00 | David C. Lonie | Assigned To | => David C. Lonie |
2015-08-19 13:00 | David C. Lonie | Status | backlog => active development |
2015-08-19 13:04 | David C. Lonie | Note Added: 0035033 | |
2015-08-19 13:04 | David C. Lonie | Status | active development => gatekeeper review |
2015-08-19 13:04 | David C. Lonie | Resolution | open => won't fix |
2015-09-03 09:53 | Utkarsh Ayachit | Status | gatekeeper review => customer review |
2015-09-03 09:53 | Utkarsh Ayachit | Fixed in Version | => git-master |
2015-09-06 12:17 | Utkarsh Ayachit | Fixed in Version | git-master => 4.4 |
2015-12-01 19:38 | Alan Scott | Note Added: 0035504 | |
2015-12-01 19:38 | Alan Scott | Status | customer review => closed |
