0015613 | ParaView | (No Category) | public | 2015-07-31 10:05 | 2016-08-12 09:59 | ||||
Reporter | Joachim Pouderoux | ||||||||
Summary | 0015613: In Python, setting the Input of the active source change the active source to null | ||||||||
Description | See example below. | ||||||||
Steps To Reproduce | - Start ParaView - Open the Python shell - Type: s = Sphere() - the sphere becomes the active source - Type: c = Clip() - now the clip becomes the active source - Type: c.Input = s - There is no more active source! | ||||||||
Additional Information | When C.Input = s is called, the selection is changed - it should not. (gdb) bt #0 pqSelectionAdaptor::selectionChanged (this=0x8978b0) at /home/joachim/dev/paraview/Qt/Components/pqSelectionAdaptor.cxx:135 #1 0x00007ffff74b021c in pqSelectionAdaptor::qt_static_metacall (_o=0x8978b0, _c=QMetaObject::InvokeMetaMethod, _id=0, _a=0x7fffffff9df0) at /home/joachim/dev/paraview-debug/Qt/Components/moc_pqSelectionAdaptor.cxx:54 #2 0x00007ffff52a51ec in QMetaObject::activate(QObject*, QMetaObject const*, int, void**) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4 #3 0x00007ffff5d4659a in QItemSelectionModel::currentChanged(QModelIndex const&, QModelIndex const&) () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4 #4 0x00007ffff5d4a9bd in ?? () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4 #5 0x00007ffff5d4d9b9 in ?? () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4 #6 0x00007ffff52a51ec in QMetaObject::activate(QObject*, QMetaObject const*, int, void**) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4 #7 0x00007ffff52f1804 in QAbstractItemModel::rowsAboutToBeRemoved(QModelIndex const&, int, int) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4 #8 0x00007ffff52862e5 in QAbstractItemModel::beginRemoveRows(QModelIndex const&, int, int) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4 0000009 0x00007ffff5d768c5 in ?? () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4 #10 0x00007ffff5d7c687 in ?? () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4 0000011 0x00007ffff5d7c8d1 in ?? () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4 #12 0x00007ffff52a51ec in QMetaObject::activate(QObject*, QMetaObject const*, int, void**) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4 #13 0x00007ffff52f1804 in QAbstractItemModel::rowsAboutToBeRemoved(QModelIndex const&, int, int) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4 #14 0x00007ffff52862e5 in QAbstractItemModel::beginRemoveRows(QModelIndex const&, int, int) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4 #15 0x00007ffff73cb904 in pqPipelineModel::removeChildFromParent (this=0x89a970, child=0x3ad2c80) at /home/joachim/dev/paraview/Qt/Components/pqPipelineModel.cxx:1059 #16 0x00007ffff73cc862 in pqPipelineModel::removeConnection (this=0x89a970, source=0x3a1da70, sink=0x3aa35f0, sourceOutputPort=0) at /home/joachim/dev/paraview/Qt/Components/pqPipelineModel.cxx:1343 #17 0x00007ffff74a995c in pqPipelineModel::qt_static_metacall (_o=0x89a970, _c=QMetaObject::InvokeMetaMethod, _id=6, _a=0x7fffffffa710) at /home/joachim/dev/paraview-debug/Qt/Components/moc_pqPipelineModel.cxx:89 #18 0x00007ffff52a51ec in QMetaObject::activate(QObject*, QMetaObject const*, int, void**) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4 #19 0x00007ffff6caadf5 in pqServerManagerModel::connectionRemoved (this=0x8a4a70, _t1=0x3a1da70, _t2=0x3aa35f0, _t3=0) at /home/joachim/dev/paraview-debug/Qt/Core/moc_pqServerManagerModel.cxx:427 #20 0x00007ffff6ca9df4 in pqServerManagerModel::qt_static_metacall (_o=0x8a4a70, _c=QMetaObject::InvokeMetaMethod, _id=31, _a=0x7fffffffa8b0) at /home/joachim/dev/paraview-debug/Qt/Core/moc_pqServerManagerModel.cxx:155 #21 0x00007ffff52a51ec in QMetaObject::activate(QObject*, QMetaObject const*, int, void**) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4 #22 0x00007ffff6ca65f1 in pqPipelineSource::connectionRemoved (this=0x3a1da70, _t1=0x3a1da70, _t2=0x3aa35f0, _t3=0) at /home/joachim/dev/paraview-debug/Qt/Core/moc_pqPipelineSource.cxx:164 #23 0x00007ffff6c524e4 in pqPipelineSource::portConnectionRemoved (this=0x3a1da70, op=0x3a1ca00, cons=0x3aa35f0) at /home/joachim/dev/paraview/Qt/Core/pqPipelineSource.cxx:194 #24 0x00007ffff6ca62b6 in pqPipelineSource::qt_static_metacall (_o=0x3a1da70, _c=QMetaObject::InvokeMetaMethod, _id=12, _a=0x7fffffffaa80) at /home/joachim/dev/paraview-debug/Qt/Core/moc_pqPipelineSource.cxx:97 #25 0x00007ffff52a51ec in QMetaObject::activate(QObject*, QMetaObject const*, int, void**) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4 #26 0x00007ffff6ca4c44 in pqOutputPort::connectionRemoved (this=0x3a1ca00, _t1=0x3a1ca00, _t2=0x3aa35f0) at /home/joachim/dev/paraview-debug/Qt/Core/moc_pqOutputPort.cxx:141 #27 0x00007ffff6c43d84 in pqOutputPort::removeConsumer (this=0x3a1ca00, cons=0x3aa35f0) at /home/joachim/dev/paraview/Qt/Core/pqOutputPort.cxx:218 #28 0x00007ffff6c4e1b9 in pqPipelineFilter::inputChanged (this=0x3aa35f0, portname=...) at /home/joachim/dev/paraview/Qt/Core/pqPipelineFilter.cxx:413 #29 0x00007ffff6c4db4c in pqPipelineFilter::inputChanged (this=0x3aa35f0, client_data=0x3a5eee8) at /home/joachim/dev/paraview/Qt/Core/pqPipelineFilter.cxx:335 #30 0x00007ffff6ca5cbe in pqPipelineFilter::qt_static_metacall (_o=0x3aa35f0, _c=QMetaObject::InvokeMetaMethod, _id=1, _a=0x7fffffffadb0) at /home/joachim/dev/paraview-debug/Qt/Core/moc_pqPipelineFilter.cxx:54 #31 0x00007ffff52a51ec in QMetaObject::activate(QObject*, QMetaObject const*, int, void**) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4 #32 0x00007ffff4603ce2 in vtkQtConnection::EmitExecute (this=0x3aa0460, _t1=0x3a21c00, _t2=33, _t3=0x3a5eee8, _t4=0x0, _t5=0x3aa0570) at /home/joachim/dev/paraview-debug/VTK/GUISupport/Qt/moc_vtkQtConnection.cxx:103 #33 0x00007ffff45e1318 in vtkQtConnection::Execute (this=0x3aa0460, caller=0x3a21c00, e=33, call_data=0x0) at /home/joachim/dev/paraview/VTK/GUISupport/Qt/vtkQtConnection.cxx:72 | ||||||||
Project | TBD | ||||||||
(0034916) Utkarsh Ayachit (administrator) 2015-08-06 21:46 |
The problem arises due to InputProperty::SetData in servermanager.py. That method always removes all proxies on the property and then adds the new value. That causes the pqPipelineModel to attempt to move the "anchoring" for the Clip filter and the input is being changed. In that kerfuffle, the active source gets reset. The issue won't arise in pvpython. |
(0038853) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-07-31 10:05 | Joachim Pouderoux | New Issue | |
2015-07-31 10:06 | Joachim Pouderoux | Description Updated | |
2015-07-31 10:06 | Joachim Pouderoux | Steps to Reproduce Updated | |
2015-07-31 10:15 | Joachim Pouderoux | Summary | Setting the Input of the active source change the active source to null => In Python, setting the Input of the active source change the active source to null |
2015-07-31 11:22 | Joachim Pouderoux | Additional Information Updated | |
2015-08-06 21:46 | Utkarsh Ayachit | Note Added: 0034916 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038853 | |
