0015616 | ParaView | (No Category) | public | 2015-08-03 18:49 | 2016-08-12 09:59 | ||||
Summary | 0015616: Trace: scalar bar visibility is not reset to off when user switches back to Solid Color. | ||||||||
Description | + Start Trace + Wavelet + Color by "RTData" + Color by "Solid Color" + Save Trace. Add the following to the end of the trace file: RenderAllViews() raw_input("Enter a key to continue...") Run the saved script in pvpython, you'll notice that the Scalar Bar remains visible (which is not the case if you run the trace in Python Shell in the UI). This is a bug. | ||||||||
Project | Sandia | ||||||||
(0038855) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-08-03 18:49 | Utkarsh Ayachit | New Issue | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038855 | |
