0015623 | ParaView | (No Category) | public | 2015-08-07 07:55 | 2016-08-12 09:59 | ||||
Reporter | Mathieu Westphal | ||||||||
Assigned To | Mathieu Westphal | ||||||||
Summary | 0015623: pvserver is not correctly handling default plugins in PV_PLUGIN_PATH | ||||||||
Description | When starting pvserver with PV_PLUGIN_PATH pointing to ./lib, the plugin window display strange results. How to reproduce ( with clean registery) : PV_PLUGIN_PATH=./lib ./bin/pvserver & PV_PLUGIN_PATH=./lib ./bin/paraview connect to server, plugin manager shows up with error. | ||||||||
Project | TBD | ||||||||
Attached Files | 2015-08-07-135316_800x600_scrot.png [^] (56,690 bytes) 2015-08-07 07:55
(0038856) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-08-07 07:55 | Mathieu Westphal | New Issue | |
2015-08-07 07:55 | Mathieu Westphal | Assigned To | => Mathieu Westphal |
2015-08-07 07:55 | Mathieu Westphal | File Added: 2015-08-07-133001_3840x1080_scrot.png | |
2015-08-07 07:55 | Mathieu Westphal | File Deleted: 2015-08-07-133001_3840x1080_scrot.png | |
2015-08-07 07:55 | Mathieu Westphal | File Added: 2015-08-07-135316_800x600_scrot.png | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038856 | |
