0015633 | ParaView | (No Category) | public | 2015-08-10 20:11 | 2015-08-11 13:29 | ||||
Assigned To | Alan Scott | ||||||||
Target Version | 4.4 | Fixed in Version | |||||||
Summary | 0015633: Interactive select points doesn't show data in realtime | ||||||||
Description | Interactive select points doesn't show data in realtime. This is one of the main drivers for this feature, thus needs to be fixed. Basically, make the interactive points the same as interactive cells. * Linux, master, local server. * Open bake.exo. All vars on, apply. * Find data. Points Labels. Choose T. Close. * Now, interactive select points on. T should be output, but isn't. If you click you get T at that point, but we are trying to get interactive - true interactive - ability to see your data. | ||||||||
Project | Sandia | ||||||||
Relationships | ||||||
(0034952) Alan Scott (manager) 2015-08-11 13:29 |
Very close to a duplicate of 15621, which is actually fixed. Closing this bug. |
2015-08-10 20:11 | Alan Scott | New Issue | |
2015-08-10 20:11 | Alan Scott | Status | backlog => todo |
2015-08-10 20:11 | Alan Scott | Target Version | => 4.4 |
2015-08-11 13:28 | Alan Scott | Relationship added | related to 0015621 |
2015-08-11 13:29 | Alan Scott | Note Added: 0034952 | |
2015-08-11 13:29 | Alan Scott | Status | todo => closed |
2015-08-11 13:29 | Alan Scott | Assigned To | => Alan Scott |
2015-08-11 13:29 | Alan Scott | Resolution | open => fixed |
