0015635 | ParaView | (No Category) | public | 2015-08-11 09:51 | 2016-08-12 09:59 | ||||
Reporter | Andy Bauer | ||||||||
Product Version | 4.3 | ||||||||
Summary | 0015635: vtkProcessIds doesn't have the proper range when doing a trace and then running in batch | ||||||||
Description | Steps to reproduce: 1) Run paraview and connect to a server run with 2 processes 2) Start a trace 3) Create a Wavelet source 4) Switch to the Surface representation and pseudo-color by vtkProcessId 5) Save a screenshot 6) Stop the trace and save the python script 7) Run the python script with pvbatch and more than 2 MPI processes. 8) The outputted image will have a range of [0,1] and there will be a warning: Warning: In /home/acbauer/Code/ParaView/ParaView/ParaViewCore/ServerManager/Rendering/vtkSMPVRepresentationProxy.cxx, line 280 vtkSMPVRepresentationProxy (0x3a02870): Could not determine array range. | ||||||||
Project | TBD | ||||||||
(0034939) Andy Bauer (developer) 2015-08-11 09:51 |
Same thing for cellNormals. |
(0038860) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-08-11 09:51 | Andy Bauer | New Issue | |
2015-08-11 09:51 | Andy Bauer | Assigned To | => Utkarsh Ayachit |
2015-08-11 09:51 | Andy Bauer | Note Added: 0034939 | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038860 | |
