0015642 | ParaView | (No Category) | public | 2015-08-13 11:59 | 2016-08-12 09:59 | ||||
Summary | 0015642: Multiblock Exodus data not always colored by vtkBlockColors | ||||||||
Description | With the upcoming release of ParaView 4.4, when you load an Exodus file the default coloring is vtkBlockColors instead of a solid color. This usually works, but sometimes does not. Here is a case where the default color sometimes reverts back to solid color. 1. Load can.ex2. Apply. 2. Split the view (either vertically or horizontally, it doesn't matter). 3. In the new view, make can.ex2 visible. In the new view, the can data have a solid color instead of being colored by vtkBlockColors. | ||||||||
Project | Sandia | ||||||||
(0038863) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-08-13 11:59 | Ken Moreland | New Issue | |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038863 | |
