0015649 | ParaView | (No Category) | public | 2015-08-13 15:04 | 2016-08-12 09:59 | ||||
Target Version | 5.1 | Fixed in Version | |||||||
Summary | 0015649: Odd warning when applying interactive selection after query | ||||||||
Description | If you try to apply an interactive selection after a query, you get an incomprehensible error box followed by the selection being cleared out. To replicate, do the following: 1. Open can.ex2. Load all variables. Apply. 2. Go to last time step. 3. Open Find Data dialog. 4. Make a cell query where EQPS >= 1.5. 5. Close the Find Data dialog. 6. Turn on interactive cell select. 7. Select a cell. At this point you get the output message "Failed to locate property: ContainingCells" (which is meaningless to users). The cell still gets selected, but the previous selection goes away. | ||||||||
Project | Sandia | ||||||||
(0038866) Kitware Robot (administrator) 2016-08-12 09:59 |
2015-08-13 15:04 | Ken Moreland | New Issue | |
2015-08-17 16:17 | Alan Scott | Project | TBD => Sandia |
2015-08-17 16:17 | Alan Scott | Target Version | => 4.5 |
2015-09-11 16:44 | Utkarsh Ayachit | Target Version | 4.5 => 5.1 |
2016-08-12 09:59 | Kitware Robot | Note Added: 0038866 | |
